First post, by Warthog
My computer stats are in my profile
The game is: iF-22 v3.3 (for Windows 95)
I got another oldie out of the closet, I know iF-22 probably won't be worth the effort to get it to run, but I'm so close.
I installed it and found the last patch for the game and applied it. The game overall runs fine. The first minor problem is the colours in the games main menus are messed up. I get light green text on a white background. I tried all screen resolutions and colors with no change. Hard to read, but tolerable.
The biggest problem is that the keyboard does not work properly. Any fucntions that I press a key once to turn something on or off work fine. But when I am flying and I need hold down a key to do something I get a strange problem. Say, I want to use the rudder, I hold the Z or X key, and instead of the rudder deflecting to the right or left, there is a delay, and then it just kind of vibrates. It doesn't respond right and is unuseable. However, I identified the source of the problem. The program is using Windows' keyboard key repeat delay and repate rate! I have never seen any thing like that before. I adjusted the rates and noticed a change, but it wasn't much better. I am using a joystick for the other flight controls, but I assume that I would not get much much response either if I used the arrow keys the fly the plane. And I did mess with the XP compatably modes, and that made things worse.
Well I thought I would work around the problem and go get a new 4 axis joystick (with a twist rudder axis.) It is a Interact Raider FX Advanced digital USB joystick with Force Feedback. Now my last experience with digital joystick was bad and thats why im still using a 2 button analog stick. I installed the joystick with all its software. Well the force feedback had no intention of working in the Joysticks own software, but I didn't care about that. The joystick worked fine another Windows 95 game I had on my computer. So then I tried to run iF22. With the joystick plugged in, the iF-22 would not even start up. I uninstalled the joysticks software, but still the game would not start up. As soon as I pull the USB cable out of my computer, the game starts up fine. So the game does not like the joystick. I tried to install the joystick as just a generic joystick, but Windows is looking for a new joystick on my game port. So that won't work. So the game does not like the joystick, but I need the joystick to play.
So I need to either get the keyboard to work right, get the joystick to work right, return the joystick and get a good old analog 4-axis stick (they don't make them like they used to), or fail.
I have several ideas on getting the Joystick to work, while I am dry on the keyboard.
Is there a way to connect the USB device to the computer by converting it to a standard Game port connector? People at both Radio Shack and Office Max told me that there is no such connector. I know there are connectors that do the reverse.
Or is there a software solution to make a device look like its not a USB but a standard game port device?
Or should I just find a old fashioned analog stick?
Reply 1 of 23, by Snover
Wow. That's a tough problem. I don't have iF-22 so I can't do any testing over here, unfortunately.
Have you tried Microsoft's Application Compatibility Toolkit? It will hopefully fix the problem.
Yes, it’s my fault.
Reply 2 of 23, by Warthog
Ok I got the ACT. hmm.. wow its quite complicated. Looks a bit over my head. ....
Ok this I good.. I think.. In the System Database list of Applications, iF-22 is listed and contains one fix. Now what do I do with it?
and... the InterAct Game Device Software (my USB joystick) is also listed with 7 fixes.
Reply 3 of 23, by Snover
I never much liked the 2.0 ACT...
okay, what you need to do is this:
  1. Run "QFixApp"
  2. Select "Win2000" in the Layers tab
  3. Go to the "Fixes" tab
  4. Check "ForceDXSetupSuccess"
  5. Check "Win95VersionLie"
  6. UNcheck "Win2000VersionLie"
  7. Click "Browse..." and find the EXE for iF-22
  8. Click "Advanced >>"
  9. Click "Create fix support" and answer "Yes" on the dialogue window that pops up
Now, whenever you need to run iF-22, it should automatically use these fixes, and it should run correctly. You may need to mess around with other shims that are provided in QFixApp, however. I just listed the two that were in the ACT database... it's quite possible that these are only fixes for the installer. 😒
I don't see any fixes for InterAct, err, anything, so I don't know what you're talking about on that front. 😜
Yes, it’s my fault.
Reply 4 of 23, by Warthog
I did that and there was no change noticeable.
I think I am going to have to set up a dual boot to avoid all this trouble once and for all. I have been told that a program like Partition Magic or something can make a partition on my HD with out having to reformat and reinstall everything, and then I can install Win98. (not Win95, because I have my HD in FAT32). Know any thing about this?
Reply 5 of 23, by Snover
Did you try using the default "Win95" compatibility layer in QFixApp? More extreme measures may also be necessary, but you can always check without making a patchfile by just "Run..."ning the game in QFixApp. (It applies changes on-the-fly.) Fiddle around with various bits, too. Fiddling can sometimes have a tendency to fix things. 😀
Yes, it’s my fault.
Reply 6 of 23, by Warthog
So here is an update on this. Partition Magic successfully make a 1GB partition on my drive. I put Windows 98 on it and installed iF-22. I got the exact same keyboard problem as I got in XP and a different graphics problem (instead of the menus being hard to read, some graphics on the screen don't show up.) But the USB joystick worked with the game! Not being satisfied, I installed Windows 95, but Windows 95 screwed itself up in a few minutes so that I could only start it in safe mode. So that being that, I installed Windows ME, which had the same results as Windows 98. So I installed Windows 98 again and I think this is as good as it will get. Although, I still wonder how the game would be in Windows 95.
The digital USB Joystick (Interact Raider Advanced FX) is the best joystick I have ever used. I was weary of it at first, because it was digital and had no trim controls, but now that I use it it's awesome! It is perfect. It has a perfect range of motion, perfectly centers itself, is precise AND accurate. It has 4 axis and none of them bleed over and affect the other axis! It's Amazing. Only downfall is that the base is small with no weight or suction cups.
So now I have two questions:
1. Are there are any recorded instances in the history of mankind of Windows XP compatibility settings actualy working for games?
2. Have the fixes listed in the ACT worked for anyone?
Reply 7 of 23, by Nicht Sehr Gut
Might be inadequacies of the video chipset. I noticed an Intel chipset that worked for most titles but had video aberrations only on certain titles. Kind of hard to tell without knowing the exact chipset.
If your motherboard is relatively new, there's a good chance it won't work properly with Win95 as it doesn't support USB, AGP video, and other hardware that's been made since '98.
1. Are there are any recorded instances in the history of mankind of Windows XP compatibility settings actually working for games?
Yes, they're perfect for some Sierra games for Windows (3.1/95). They actually work better for me in XP than in Win9x. This is because they require 256-color mode and only fill the screen when it's in 640x480 mode. That requires manually changing both settings in Win9x. Using compatibility mode in XP, it's automatic and reverts back to my normal screenmode when I quit the game. Very nice.
Don't know about your second question (ACT), though.
Reply 8 of 23, by procerus
You can use PowerStrip's application profiles to achieve the same thing on Windows 9x/ME but I can see it would be preferable if it were built in to the OS.
98lite with 629K of free conventional memory in full DOS mode using QEMM 9.0 (or 628K with UMBPCI.SYS providing real mode for FastVid) with SmartDrive, CD-ROM, CuteMouse, sound support and UniRefresh all loaded high.
Reply 9 of 23, by Warthog
Its an Intel 810 graphics chipset. I will be getting a real graphics card, im looking at a few, but I'm waiting to find a good deal. Hopefully that will fix that graphics errata.
Reply 10 of 23, by Snover
http://www.monarchcomputers.com usually has some great deals on OEM parts. You should be able to get a GF3Ti500 for really cheap now, though. That's my recommendation if you're looking for a sweet card for cheap.
Yes, it’s my fault.
Reply 11 of 23, by Nicht Sehr Gut
procerus wrote:
... but I can see it would be preferable if it were built in to the OS.
Correct, I was comparing OS-to-OS. You can use a separate tool, but my tool tray's pretty saturated as is.
Reply 12 of 23, by FIVE-one
Same problem as above. The game seems unable to launch with a USB controller plugged in. (on Windows 10)
Hail to the Emperor !
Reply 13 of 23, by ChronoReaperX
iF-22 Persian Gulf V5.0 is playable via DDrawCompat. My specs are Intel Celeron 2.1Ghz N2840 + Intel HD Graphics + 8GB DDR3 L RAM. Running natively on Windows 8.1 (and should work the same on Windows 10 & 11).
I've managed to solve the controller part by using a combination of x360ce (to hide the USB controller via the HIDGuardian function) and DS4Windows (with ViGEm + Bluetooth DS4). I am also using a specific DxWnd version & an imported profile (from the SourceForge forum discussing about iF-22) to make the game run on a single core-affinity processor with some colorkey fix. The only compatibility settings I used on the game .EXE is "run as administrator".
It still has multiple problems ranging from occasional freezes (after jet crashes/ exiting a mission), missing transparency effects & textures (becoming black boxes) when using Direct3D rendering, and the menu... which is accessible and working fine but the graphics are broken with white background at the supposedly black button/ link/ text area.
Reply 14 of 23, by ChronoReaperX
GUIDE TO USE A BLUETOOTH CONTROLLER (DS4) FOR IF-22 PERSIAN GULF V5.0 TO PLAY NATIVELY ON MODERN WINDOWS
Assuming that you've already download and install both x360ce v4.x (with HIDGuardian) and DS4Windows (with ViGEm), please follow the 5 steps below:
1) Make sure DS4 controller (via wireless Bluetooth) is off.
2) Open x360ce program, go to DEVICES and tick HIDE for the X360 USB controller (or any other USB wired controller attached) ONLY.
3) Make sure that USB wired controller is disappear from the "Set up USB game controller" list in Windows. The list should be empty (no controller is detected).
4) Open DS4Windows program which is pre-configured to automatically use a virtual X360 controller (XInput) with the DS4 if being detected.
5) Start iF-22 game by clicking the shortcut & wait a few seconds (depends... mine is until 4 seconds) before pushing PS logo button of the DS4 to start the controller. If failed, close the game & turn off DS4 then repeat again.
*Skip step 2 & 3 if you don't have any USB controller (like the X360 wired controller) plugged in to your computer. You might not need to download x360ce at all if you don't have or not using any USB wired controller.
*Use DXWND to start a game (currently used for the game) so that the starting sequence can make a brief "gap" in time for the Bluetooth controller to work and the game can start normally (showing on screen, not just running in the background in Task Manager)
*You can also try & test any other Bluetooth controller out there besides DS4, but the bottom line is, the Bluetooth capable controller must be made "virtual" in order to use XInput for the game to recognize it.
*The game will not showing on screen when start (but running in the background in Task Manager) if it detect any HID/ USB controller connected prior to launch. The game will not recognize DS4 (DInput) unless via a virtual controller emulation (ViGEm in DS4Windows) with X360 controller preset only (using XInput).
*Do not exit both x360ce & DS4Windows program before & during iF-22 gameplay. Let them minimize. x360ce is prone to freeze during this process. Use Task Manager to turn it off after exiting the game.
*Make sure the X360 USB controller (or any other USB/ wired controller attached) reappear in the "Set up USB game controller" list in Windows after turn off x360ce. If not, restart x360ce & tick/ untick the HIDE box in the program.
Reply 15 of 23, by darkenedroom
So just to summarize as I've been looking at this (iF-22 v5.0) recently and this looks like a really good discovery.
DInput controller are a complete no go, which is what I also discovered when trying to get it to work under WIn10. Had more success with PCem/86Box.
But an XInput controller, real or virtual seems to work fine with the sim?
So with a DInput HOTAS it seems like using the ViGEmBus Driver and something like XOutput (for example) would allow a virtual XInput device to be created with 4 axes (pitch, roll (joystick x & y), thrust (throttle) and yaw (rudder pedals)) ?
If so that suggests the sim might be playable under WIn10 with a joystick/HOTAS?
https://www.tales-from-darkenedroom.com/ - Retro PC gaming on Windows 10, technical aspects, flight sims and space sims a speciality
Reply 16 of 23, by ChronoReaperX
darkenedroom wrote on 2026-06-09, 17:30:
So just to summarize as I've been looking at this (iF-22 v5.0) recently and this looks like a really good discovery. […]
Yes you could try and test it. Follow my guide or improvise and experiment with it as you wish.
I'm using Dxwnd v2.04.26 build and download the profile (for IF-22 Dxwnd) + the dxwnd.dll file from this forum: https://sourceforge.net/p/dxwnd/discussion/ge … hread/6aa4a166/
Combined with DDrawCompat Ver.0.5.4 (works for me)
BTW I like your blog on sims. Good effort Mr.
Reply 17 of 23, by darkenedroom
I think I know what the problem with this game 'might' be and it's not USB joysticks. I think it might be the USB'ness of everything else.
So the game uses directinput (dinput) to enumerate devices since it uses DirectX5. But the classes of enumeration are keyboard, mouse and joystick. And by joystick it seems to mean everything else which isn't a keyboard or mouse. So if the game tries to enumerate joysticks it'll find joysticks and probably a whole host of others devices and this I believe is the problem, because the problem isn't USB joysticks.
Because if it was, then if I use HidHide to hide everything apart from my USB Warthog joystick, trying to start iF-22v5 should fail, it's a USB joystick. But it doesn't... it starts (intro movies don't work, I can't calibrate the joystick and it doesn't work in flight) but the game does start.
So I think the game is still enumerating USB things it shouldn't really be concerned about and allocating the wrong USB thing as a joystick but the USB joystick itself doesn't seem to be the problem.
So in theory you could create a dinput wrapper to ignore all the other USB devices (somehow) and only enumerate actual joysticks and I think this is what would make it work under Win10/11.
Anyway I'm no windows DirectInput expert so if I'm completely off track, let me know.
Reply 18 of 23, by ChronoReaperX
darkenedroom wrote on 2026-07-21, 19:15:
I think I know what the problem with this game 'might' be and it's not USB joysticks. I think it might be the USB'ness of everyt […]
Good findings. So far, I am comfortable with my DS4 Bluetooth solution, combined with DDrawCompat & DXWND as further discussed in https://github.com/narzoul/DDrawCompat/issues/603
Reply 19 of 23, by darkenedroom
So another update :
The game doesn't use DirectInput but WinMM as the joystick mechanism. This was determined by using Xidi with the Hookshot injection mechanism, this reveals that WinMM is used as Xidi/Hookshot adds a winmm.dll wrapper and not a dinput.dll wrapper. Now the problem is that most winmm wrappers concentrate on the audio/midi side of things and not the joystick side (would be happy to be proved wrong in this conclusion).
The game seems to have a serious issue with DirectInput devices and basically fails to start if it can see any. However it can be made tolerant of a vJoy virtual joystick being present if not being used.
So using a combination of HidHide to hide physical DirectInput devices and leaving vJoy visible and Joystick Gremlin to map axes/buttons to the vJoy joystick and also using vJoy to create the virtual joystick you end up with a single visible vJoy virtual joystick. This combo would also allow you to use any vendor physical device and map excess buttons to keyboard key presses.
This is no good for iF-22v5 as it's still a DirectInput device, however you can use XOutput to create a virtual XInput device from the vJoy virtual joystick.
The final piece of the puzzle is using RetroBridge created by rkk which includes a winmm wrapper that deals with the joystick and midi/audio bits. The RetroBridge wrapper can creates another virtual joystick device with 2 axes, 4 buttons and a pov hat that communicates with the XOutput virtual XInput device.
So we have:
  • Physical DirectInput devices (hidden by HidHide) mapped to a vJoy virtual DirectInput device.
  • The vJoy virtual DirectInput device mapped to an XOutput virtual XInput device.
  • RetroBridge winmm wrapper taking the virtual XInput device and mapping it to a virtual joystick device (2 axes, 4 buttons, pov hat) which works in iF-22v5.
Surprising this whole weird combo of stuff actually manages to work as shown by this YouTube vid.
