Reply 20 of 487, by Solarstorm
- Member
wrote:Current Progress:
Now i'm Searching a way to reset attiny on System Reset.
I think you could use B2 on the ISA bus.
http://pinouts.ru/Slots/ISA_pinout.shtml
RESET
This signal goes low when the machine is powered up. Driving it low will force a system reset. This signal goes high to reset the system during powerup, low line-voltage or hardware reset. ??????????????
