First post, by Deksor
Hi everyone !
I never used SystemSoft Cardwizard and I don't really know what to do with it ...
Here's the configuration under Windows 95 :
5.16 KiB
I guess with config.sys I need to load the drivers, so far what I did was
DEVICE=C:\CARDSOFT\SSCIRRUS.EXE
DEVICE=C:\CARDSOFT\CS.EXE
DEVICEHIGH=C:\CARDSOFT\CSALLOC.EXE
DEVICEHIGH=C:\CARDSOFT\CARDID.EXE
I guess SSCIRRUS.EXE is the driver, however I don't know which one to choose as there are 3 manufacturers for cardbus in my computer according to the device manager of windows 95. The actual configuration doesn't seem to work as when I launch "CARDID.EXE", it reports "cannot read the card from library"
I'm completely lost here x)
Reply 2 of 7, by Deksor
It says "Slot 0:
Slot 0 is empty
Slot 1:
Slot 1 is empty"
Even though I have a 3com NIC in one of them (and the slots don't seem to initialize as the NIC's lights aren't turning on)
Reply 4 of 7, by Deksor
No, but I can start whatever "SSxxxxx.EXE" program and they won't complain about anything so I don't think SSCIRRUS.EXE really work. I don't know which one I should start (if any). Are there other program for this available on the internet ?
Reply 6 of 7, by Deksor
Sorry for the late answer ...
So, in the bios there's nothing to tweak about pcmcia.
Tellme reports
Tell Me The PCMCIA Host Adapter  Version 2.25.1 (Mar 31 1997)
Copyright (C) OSITECH Communications, Inc. 1994-1997. All rights reserved.
Testing for PCI BIOS ... PCI Configuration mechanism 1
PCI BIOS detected.
Scanning for PC Card bridges ...
Texas Instruments PCI-1250 CardBus Revision ID 02h
Base Address 003E0h
[03E0, 00]
[03E0, 40]
Number of Sockets Detected: 2
Reply 7 of 7, by lolo799
The SS***.exe have to be loaded from config.sys, and they should complain when they don't find their chipset...
Cardsoft Socket and Services are quite old relative to Cardbus so it probably doesn't support your chipset, however Cardware 7 does:
http://www.tssc.de/site/products/cardware/cwdw/default.aspx
