First post, by CaelThunderwing
i know theres one out there but thats 128MB in size, i've trie dto set the ramboth dynamic and static in creatives soundbank managerto as precise it'll let me in one of my 98 machines w/ an Audigy 2but while it'll say "Loading..." it just refuses it after a few i manage dto find another but not exactly... that great either,
any others out there that are decent that'll load or is there a soundfont manager for the audigy cards that will load this one out there thats 128MB?
as for this "iffy" one? i've attached it below i dont recall where i got it from though..
(as about my last post about MIDI Troubles its oddly isolated to Windows Media player 6.4 and the "Mplayer" thats in 95/stock 98 has no issue doesnt throw any Errors at all when playing. )
    OPL3.zip
    3.05 MiB
    416 downloads
Reply 1 of 2, by LSS10999
You need to allocate slightly more RAM than the size of your soundfont in order to get it working. As Audigy exposes two soundfont synths, you need to allocate more RAM than the soundfonts loaded on both synths combined. Assuming you'll keep the original 4MB soundfont bank on the other synth, you need to allocate at least 136MB just to be safe.
Reply 2 of 2, by RFVogons
Wow! The linked "iffy" soundfont works, and it's good. I tested it in my host PC, with VirtualMIDISynth. More information here: https://coolsoft.altervista.org/en/virtualmidisynth 😉 Compared it to the SoundBlaster AWE32 OPL sound, it sounds surprisingly accurate. Just gonna use this soundfont for OPL now. (And only 3 MB, wow 😮)
Also, if you ask me where I did got the word "iffy", it's from CaelThunderwing's message:
~RFVogons
P.S. The comparation sounds are here, you might need to turn up the volume (music used: In The Hall of the Mountain King.rmi):
