First post, by mdfrankaudio
Does the SC-88 sound *exactly* like a SC-55mkII in this mode? Any weird compatibility problems? I'm mainly looking at the SC-88 over it because of the increased polyphony (64!) for GM MIDI files, not quite so interested in the SC-88 sound set itself.
Also how is the sound quality/DAC output compared to the SC-55? Thinner sound, fuller...?
side note: I have an original GS-only SC-55, but the note dropping is at crazy unacceptable levels for later MIDI music (to be specific, I was playing back the game Claw's XMI music) - plus no proper GM.
Reply 1 of 9, by derSammler
Not sure if it's the same with the SC-88, but for the SC-88 Pro, selecting the SC-55 map is not enough to get the same sound, as that only maps the instruments like the SC-55, but that's not really important, as it doesn't affect the 128 GM instruments anyway. Audible differences in GM are only due to other parameters changed as well.
To get the same sound as an SC-55, you must enable SC-55 compatibility mode. I've posted the infos on how to do that here.
Reply 2 of 9, by tpowell.ca
Everything I've read suggests that the SC-88 and SC-88Pro sound the same in SC-55 mode, and neither is accurate as they use a different (updated) synth engine. They also both have the same output circuitry thus sound the same quality-wise.
The SC-88Pro basically supports more effects, had more ROM for added instruments.
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 3 of 9, by Shponglefan
In my testing, switching the SC-88 Pro to SC-88 compatibility mode w/ the SC-55 map doesn't make it sound like a real SC-55. It just sounds like an SC-88 with the SC-55 map.
My benchmark for this is the Doom menu music. On a real SC-55 there is a distinct filter-sweep synthesizer sound. On the SC-88 or 88 Pro (regardless of mode/map), it sounds different.
Same thing can be heard in the Descent level 1 music.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 9, by Shponglefan
I can't speak for the Mk II, but in comparing the SC-55 Mk I with the SC-88 w/ the SC-55 mapping, they don't sound identical. They're close, but definitely not identical.
Reply 5 of 9, by James-F
They don't sound the same.
The SC-88 on the "SC-55 MAP" has more than a few sounds taken from the SC-88, most popular is the kick drum and ride cymbal in Duke3D track, but there are more.
Listen here for Duke3D Intro track.
http://www.wavetable.nl/category/comparisons/
Reply 6 of 9, by tpowell.ca
Speaking of the SC-55, (mk I unit) for the best DOS retro western game compatibility (eg: Sierra, Lucasarts, Dynamix) is there a difference between units with ROM versions 1.2x and 2.00?
I know for a fact that they all have a GM mode (not selectable like on mkII units) but what's not clear is if the infamous Capital Tone Fallback is supported on ROM version 2.00.
Reply 7 of 9, by mdfrankaudio
James-F wrote:
They don't sound the same. The SC-88 on the "SC-55 MAP" has more than a few sounds taken from the SC-88, most popular is the kic […]
Is the 8820 identical to the SC-88 in this case (because an 8820 is what was used in that clip)? That's quite a difference... I prefer the drums in the SC-55 clip on there versus the "SC-8820_55MAP" - the whole song sounds a little tighter overall on the SC-55.
I may have to look for BOTH a mkII for GM support and the slightly extra polyphony, AND a SC-88 for later MIDI that needs the extra voices.
Reply 8 of 9, by James-F
Yes.
Also, some string instruments are different, so Warcraft 2 will not sound the same.
Moreover, some Envelope range differ form SC-55 and SC55-Map.
In short, if you want a SC-55 sound, buy a SC-55.
I suggest SC-55 MKII for everything MIDI related.
Reply 9 of 9, by j^aws
15.38 KiB
I remember comparing a Roland SC-88ST with the SC-55 map, and a CM-300 (home version of SC-55), and the main difference I could hear was better clarity from the SC-88ST. Tried various games and just ended up using the SC-88ST instead.
