First post, by Marty2dos
Hello,
I Wonder. In the Compatibility Page of Dosbox it say it full supportet.I tried many Dosbox Version, down to version 71 and other Forks.
The Vector Grafic is damaged. The one and only where it works is Dosbox-X.
All Ports
Dosbox-X
Anyone has a Code Solution? Or to the Dosbox-X Author. Can you give me hint where did you fix this?
Reply 1 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Hello, sir! What are you up to?
This appears to be a CPU emulation issue in the normal core regarding undocumented (or at least poorly documented) behavior of certain flags for divide instructions; in this case the overflow flag for a word-size integer divide. It's somewhat related to an issue with a different game: The Perfect General I and DOSBox fail help
PCem and DOSBox-X unconditionally clear the overflow flag for divide instructions, and that does seem to make the game generally work okay. Still, it'd be pointless to check a flag that's always clear, but perhaps the game developer thought it means something when in fact it does not.
A possible workaround for the issue is to set core=dynamic; however, it probably depends on the build of DOSBox and the host system. The game works okay for me with core=dynamic and 32-bit builds of 0.74 and SVN on Win10 x64.
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
Ah, there are a few more flags worth fixing. I recall that our overflow is wrong for left shifts
https://c9x.me/x86/html/file_module_x86_id_285.html
The OF flag is affected only on 1-bit shifts. For left shifts, the OF flag is set to 0 if the most significant bit of the result is the same as the CF flag (that is, the top two bits of the original operand were the same); otherwise, it is set to 1. For the SAR instruction, the OF flag is cleared for all 1-bit shifts. For the SHR instruction, the OF flag is set to the most-significant bit of the original operand.
Although I don't know if a game is affected.
Water flows down the stream
Reply 3 of 4, by Marty2dos
Hello ripsaw8080,
thanks for your answer.
I tried with core=dynamic but the vector gfx is damage too??? 😕
hello Qbix,
thanks for your answer too. This is the keyword. i looked in the dosbox port and i changed 2 sources. in the flags.cpp and instructions.h
i added only the parity16/32 and SETFLAGBIT from "DOSBox-X-20150818_v0.801 Next B1" Port. (at this release Thalions Airbus A-320 Works). Now it works in my build 0.74 r4088. Core=auto/ cputype=auto 😊
    instructions.h
    30.45 KiB
    92 downloads
    flags.cpp
    24.48 KiB
    91 downloads
Reply 4 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Well, as I said, the dynamic core workaround depends on the host system.
Also, if you follow my previous comment, one only need add a SETFLAGBIT(OF,false); for IDIVW in instructions.h to fix this particular game, but the flags should be fixed properly (as soon as it can be determined what is proper 😉 )
