First post, by VooDooMan
Does anyone know where I can download the driver that enables the Eagle-Eye: Wireframe and Transparency features on SiS Xabre cards?
Those features are described in this article:
https://techreport.com/review/4015/sis-xabre- … ics-processor/3
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 1 of 15, by chose007
Interesting, never seen this.
I'am not promising something big but I got original CD with one of my Xabre so can watch to it (if I will find it)
Reply 2 of 15, by chose007
readme from my CD, almost 300MB but 3DWizard folder only 2MB
Reply 3 of 15, by VooDooMan
Thanks! I also have the original CD but those drivers are not there... They were not very popular, and now they are nowhere to be found on the internet...
Let's just hope somebody has them on the hard drive and will share them here 😉
BTW. I like your page on Facebook 😁
Reply 4 of 15, by chose007
Then you need find driver from 3D glasses card version ... this can be quite hard.
Thanks
Reply 5 of 15, by B.Gumble
This is on my CD from my Triplex Xabre Ultra
Reply 6 of 15, by VooDooMan
I am still looking for those drivers. They have to iclude the 3D Wizard version 1.6.
http://www.3dvelocity.com/reviews/SiS%20Xabre400/xabre3.htm
I need the following drivers to check if the egle-eye option is included there:
- 3.01.02
- 3.02.53
@ B.Gumble, What version do you have? I can see there is 3D Wizard, but you would have to check if there is Eagle-Eye option. It is not always there.
I used the 3.57.53 drivers - 3D Wizard is there but no Eagle-Eye option 🙁
Reply 7 of 15, by VooDooMan
So far no success...
I tired the following drivers:
3.02a.02 (3021) - no 3D Wizard
3.02.53 (3020) - no 3D Wizard
3.06.1.02 (3060) - no 3D Wizard
3.09.52 (3090) - 3D Wizard is there, no eagle eye
3.10 (3100) - 3D Wizard is there, no eagle eye
3.57.53 (3570) - 3D Wizard is there, no eagle eye
Reply 8 of 15, by chose007
For your info - I'am just using Xabre 400 with driver 3.03 from my CD and 3D Wizard is without features.
Reply 9 of 15, by MERCURY127
Try set option 3dSeeThrough=1 instead default 3dSeeThrough=0 in setup.ini file in usual Xabre driver folder before driver install.
Reply 10 of 15, by chose007
What will change with this? I made some tests, gaming and results surprised me. I waited lower power in 3D.
Reply 11 of 15, by MERCURY127
I think, its can help enable Eagle-Eye. if no - sorry 😀
i cant check it - i havent sis vc.
Reply 12 of 15, by chose007
OK thanks, will watch for it.
Reply 13 of 15, by Tuxality
I've just saw this thread, 3D Wizard is just a mere registry editor, nothing more than that. You don't need it, the functionality is present in the drivers, just try to set SeeThrough (should be SiS.3D.SeeThrough in registry?) to value higher than 0 in a similar fashion to setting TexTurbo in Xabre drivers. Should work for both, Direct3D and OpenGL.
Reply 14 of 15, by Vogon Will
Who got it, can you share?
Reply 15 of 15, by Vogon Will
it works!
download this
https://archive.org/details/sisvga-v-14.7z
first edit aplication\3dwizard\setup.ini
1 intall utility and driver
2 install 3D wizard
