Reply 23120 of 52809, by gdjacobs
NamelessPlayer wrote:
-Rocketfish 900W 80+ Silver modular PSU, sealed in box. Hardly vintage, but how many PSUs that specced-out do you see being sold for under $20? If anything, I'm running short on ATX PSUs for all my systems!
I'm not saying this is the case with Rocketfish. I'm not familiar with their PSU line. However, specs are easy if they're invented from thin air.
Reply 23121 of 52809, by NamelessPlayer
I'm well aware that specs aren't everything when it comes to PSUs. Especially when they don't have a review with ripple measurements backing 'em up.
But regardless, even if it only delivered half the wattage, it should be sufficient as a backup unit. Full modular cabling is icing on the cake. (Not that I should expect to need this any time soon; my main systems generally run on Super Flower, Seasonic or Enermax-based units, admittedly overkill for what they're powering. Especially the EVGA-badged Super Flower example, it's basically a 1300W Leadex. Bring on HEDT!)
Also, while Rocketfish isn't one of those top-tier brands, they've been known to rebadge surprisingly high-end things like cases.
If anything, what I really need is a TFX or FlexATX PSU that can deliver 400W of clean power and not assault the eardrums of everyone in the room, and getting one of those without spending a good chunk of change is a pain. But alas, that's what you gotta do when it comes down to replacing failed MDD G4 PSUs and fitting them loosely in the original proprietary PSU's location. (Typical ATX PSUs are way too big and require getting rid of the entire optical drive cage.)
Reply 23122 of 52809, by Baoran
Brickpad wrote:
Baoran wrote:
I bought this 486 33Mhz pc from local auction site for 50 euros. No display or keyboard comes with it though. I think the case looks pretty good. if I would want to buy a pc from ebay, I basically would have to pay 50 euros just for shipping it to my country, so that is why I don't have many old cases. Hopefully it will arrive later this week.
I have the same case as well! The 3.5" turbo / reset / LED faceplate is removable and can be placed anywhere in the 3 external 3.5" bays.
Do you happen to know how you configure the number display on this case?
Reply 23123 of 52809, by PCBONEZ
Take a look at SFX.
In photos they look just like ATX but that's an illusion. They are much smaller than they appear.
They also go to higher watt ratings than TFX or Flex usually do.
Reply 23124 of 52809, by dionb
PCBONEZ wrote:
Take a look at SFX. In photos they look just like ATX but that's an illusion. They are much smaller than they appear. They also […]
Take a look at SFX.
And BeQuiet has a nice range of them, which is good news, because BeQuiet's PSUs generally do what the name suggests 😀
Yesterday my salary came in, so of course I just had to mess around on various sites hunting for hardware - and looks like I got lucky. This Saturday I'm going to pick stuff up, so expect a few nice (if very yellowed) pics. One seller has a complete "Windows 95 system", with desktop AT case, Chicony keyboard, mouse, speaker & CRT. No idea on rest of specs, but worth it for the case alone and whatever is inside it at least works. Then driving on to another who has three cases and a monitor. Also no idea about specs, but one case is a Packard Bell Squarius uATX from 1998-1999, so a perfect home for my MSI MS-6168 (Packard Bell Bora Pro). One of the other two is older (with yellowing to match) which makes me optimistic about the contents. Worst case I get an AT desktop and a Packard Bell case I wanted, best case... who knows 😉
Reply 23125 of 52809, by OldCat
Bought two keyboards and a mouse for my Highscreen AT build (showed case here a while ago):
428.31 KiB
One of them is Cherry, one is working. 🤣 So cleaning and peroxide time, I guess.
Reply 23126 of 52809, by Murugan
OOOOO could use them too for my Highscreens :p
Nice!
Reply 23127 of 52809, by brostenen
Just got these two sticks of identical 72pin Ram.... I have never seen such large modules in person before.
Are these ECC modules? I can't tell such things without googling the specific hardware in question.
554.61 KiB
444.06 KiB
Reply 23128 of 52809, by luckybob
Got a great Craigslist score:
Got both for $20. Hell, the travel bag is worth that! A Macintosh SE with a hard drive, and a Classic. I was told one didn't work, but I will go through both and ge them tip-top. I have no idea what the serial port on the Classic is for, but I'll find out later today!
Reply 23129 of 52809, by Cyrix200+
luckybob wrote:
Got a great Craigslist score: […]
Cool. I'm not an Apple guy but I have always liked those kind of Macs. That serial port lookg like a ghetto mod 😀
1982 to 2001
Reply 23130 of 52809, by luckybob
It's actually quite complex!
I've only just started messing with this, but the factory motherboard needs to be recapped. A simple and cheap fix. But the upgrade clamps over the 68000 processor, and "upgrades" the system to a 68030@25mhz. It's like putting a 386 on top of a 8088. ALSO, it isn't a serial port, but a monochrome "1-page" monitor port with the option for a 2nd! (not installed) The previous owner actually did WORK on this machine!
Reply 23131 of 52809, by Cyrix200+
Oh wow, nice! I did not expect that!
luckybob wrote:
It's actually quite complex! […]
7LyXxvXm.jpg <snip>
1982 to 2001
Reply 23132 of 52809, by keropi
wow a 030 accelerator as well? epic score in my book!
Reply 23133 of 52809, by tegrady
brostenen wrote:
Just got these two sticks of identical 72pin Ram.... I have never seen such large modules in person before. Are these ECC module […]
Yes, that is ECC. You can tell by the extra chip in the center.
Reply 23134 of 52809, by Almoststew1990
I bought an X1650 Pro 256Mb for my Pentium 4 machine. Quite an odd looking thing really, 1.5 slot cooler but "low profile" sort of thing. Should be a nice upgrade over my MX440.
Reply 23135 of 52809, by brostenen
Cool... Then I guess that a price tag of zero (only paid for shipping) is well in order.
Reply 23136 of 52809, by dionb
Er no, the extra chip only tells you it uses some form of parity. For regular parity you need one bit extra for every 8 bits, for ECC you need two bits extra. So you need to know the specs of the extra chip to be sure. If it's the same as the rest, it's just regular parity. If it has twice the capacity, it's ECC.
Reply 23137 of 52809, by Brickpad
Unfortunately I don't. I put it away in storage at the moment. If you can get the numbers off the back of the display (if there is any), we may be able to figure it out.
Reply 23138 of 52809, by The Serpent Rider
Doesn't look like simple parity - 28-pin chip.
Reply 23139 of 52809, by dionb
Agreed, but it's that - and not the simple fact that it has one more chip - that potentially makes it ECC. And even then you see some weird parity and ECC setups out there, so I'd want to know what 28p chip that is before making any statements.
