First post, by peklop
i bought old external CD-ROM drive for LPT port without driver and power adapter. And i cant find that.
Drive is:
TransCD version A4
TCD8X-L
MTS FX800 (original internal drive was Mitsumi FX800 ???) 02/1997?
FCC ID: KDF01TC307 - Fidelity
Assembled in USA
Internal drive is interesting:
IDE / ATAPI
IMES ICD-1200/AT
Made in Japan
FCC ID: L68ICD1200AT
February 1998
sealed with anti-dust tape
probably drive was changed from bad Mitsumi after one year of working
External ports: LPT in an out, audio cinches and second audio connector (4pin like internal)
DC POWER IN is special: Square with two cutted corners and 3 PINS -
unknown Voltage
i need pinout for power adapter
I opened drive but control chip is unreadable.
Is covered by DONT TOUCH tape with Skull and Bones
Under tape is another label. Black with logo:
FiT
FIC601 A
under this label is not any other writing
Please when i find driver and pionout?
Thanks
Reply 1 of 2, by dr.ido
If the power connector has 3 pins it is likely they are +5V, +12V and ground. It would be easy enough to find which is which by probing the molex power connector for the CD-ROM drive.
