First post, by Mike
Is one possible reason why my 3d engine games (Descent, Descent 2, Terminator, etc.) do not work on my machine is because I have too much RAM? A DOS machine ususally should have only 64 MB RAM, if more than 64 MB, some games will just not run. My Pentium 200 has about 128 MB ram.
Should I remove 2 out of the 4 memory sticks to decrease the amount of RAM to 64 MB, or should I remove PC DOS 6.3 and install MS-DOS instead?
To satisify the guidelines...
AMD Pentium 200
128 MB RAM
Sound Blaster 16
PC DOS 6.3
Reply 1 of 9, by Reckless
Certain versions of DOS4GW can only address 64MB so you have to ask why you have so much more than this in a DOS machine! It's also kinda amusing to read that you've 'about' 128MB as well 😀
Anyways V2.00 of DOS4GW should have fixed the crash issue when more than 64MB is present. The latest version of DOS4GW is V2.01 and I think there was a thread around with downloads to all the available versions. Also you may want to consider using the replacement extender DOS/32.
Best of luck!
Reply 2 of 9, by Mike
I was right, I do have too much RAM!! THX for the help, now I might as well remove the 2 memory sticks, and I should be playing!
I don't want to bother with going to 2.01, but thx for all the help!
Reply 3 of 9, by HunterZ
I would also recommend trying DOS32A, as Reckless mentioned. It works as a drop-in replacement for DOS4GW and is being actively developed.
Reply 4 of 9, by Mike
Actually, I got this problem completely solved yesterday, and I don't need to do any ''extra'' things to get it going. Anyway, thanks for the advice that y'all have given.
Reply 5 of 9, by HunterZ
Would you mind describing your solution in case someone in the same situation finds this thread?
Reply 6 of 9, by Reckless
I think he removed two sticks of RAM?!
Reply 7 of 9, by Mike
Look, what I did was opened up my PC case, looked at the 4 NVRAM sticks and pulled 2 of them out, so now my machine has 64 MB of RAM instead of 128 MB. Got it?
Reply 8 of 9, by HunterZ
🤣 yeah thanks.
