First post, by feipoa
Is there any difference in image quality between the various manufactures of the original Voodoo 1? Obviously the comparison would be done on the same system with the same pass-thru cable. Has anyone looked into this? I recall reading in the forums that the Voodoo doesn't have the clearest display, but is manufacturer better than the other? Is one worse than the other?
Reply 1 of 16, by The Serpent Rider
Didn't noticed much difference, all look somewhat blurry. Maybe in some special cases like Canopus or Quantum3D cards, but I have only their V2 variations to judge.
Reply 2 of 16, by feipoa
Which brands did you try?
Reply 3 of 16, by leileilol
They've all got the same 4x1 filter. It's always going to be blurry. It's not the passthrough cable.
You can turn this filter off by setting SST_VIDEO_FILTER_DISABLE to 1.
Reply 4 of 16, by swaaye
It's crazy sounding, but I used to like to run my Matrox Mystique's 3D acceleration instead of the Voodoo sometimes because of how sharp and crispy it was by comparison. I specifically remember doing that with Jedi Knight.
Reply 5 of 16, by feipoa
Did you try leileilol's comment to set SST_VIDEO_FILTER_DISABLE to 1 and compare with the Matrox Mystique?
Reply 6 of 16, by swaaye
I don't know if I've tried that. It's a good idea, especially if using an LCD that's already causing some blur.
Reply 7 of 16, by feipoa
Its on my list now, but not sure if I'll get to it before I die.
Reply 8 of 16, by Unknown_K
The Orchid Righteous 3d has the best quality because it uses mechanical relays for video switching while all the others use solid state relays that will slightly degrade video quality. Other then quality of the pass through cable the other models should be about the same.
Reply 9 of 16, by F2bnp
Some games do look better without any filtering, especially compared to the simple bilinear filtering of the time.
To this day, I enjoy playing Quake 1 more with filtering disabled, despite using modern source-ports.
There was a thread here a few years ago with direct captures from elianda, showcasing the filters on and off (there's also the 24bpp one). Don't have a link handy, but it should be pretty easy to find.
Reply 10 of 16, by feipoa
I saw elianda's thread on this, however, I noticed very little between the screenshots. Perhaps its my monitor.
Reply 11 of 16, by mcobit
I have an "unbranded" VooDoo 1 card that produces horrible interference even with good passthrough cables on LCD monitors. It's a bit better on CRTs. Mostly two parallel lines of fuzziness in the screen center. If I touch the VGA port those change but never go away completely.
A Diamond Monster VooDoo 1 in the same system doesn't have those problems.
Reply 12 of 16, by feipoa
Interesting. Is this issue related to capacitors or the different RAMDAC used?
Reply 13 of 16, by mcobit
I have yet to find out.
Reply 14 of 16, by feipoa
Could you share a photo of the card?
Reply 15 of 16, by mcobit
Sure. Not at rhe moment unfortunately.
Reply 16 of 16, by anthony
Q3d cards are the worst
