Packard bell PB450 repair / mods / upgrade
First post, by ahtoh
Hi, I have a PB450 motherboard that won't turn on.
The monitor seem to turn on but stays black and I get two beeps.
I already tried changing the memory, disabling onboard memory and also tried to connect external cmos battery but it did not help
Anyone knows what could be the problem?
Reply 1 of 189, by Roman555
Do you have this model? http://www.uktsupport.co.uk/pb/mb/450.htm
If so check J19 that enables onboard video
Maybe two beeps suppose you press "F1" key because of some error during the start
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 3 of 189, by bjwil1991
How about the processor? Is it currently installed or was it removed at one point in time?
Also, check to see if the Parity (J18) is set to pins 2-3 or 1-2 and install a battery on the jumper for the battery since the one that's on there might be dead.
Check for oxidation by spraying contact cleaner in the VGA port as well.
Reply 4 of 189, by ahtoh
The processor is OK, I also tried replacing the CPU from another board.
I also believe the memory is OK
The reason why I think so is because I was able to flash the bios using built-in recovery routine (using J17)
I think it requires working CPU and memory
Reply 5 of 189, by bjwil1991
That's true. Did you change the jumper for the recovery (boot block) mode back to normal mode afterwards?
Reply 6 of 189, by Roman555
If you have the ISA Bus Extender (riser card) and an ISA videocard you can disable built-in video and try discrete one.
The reasons are:
1. maybe onboard video is PCI and because of broken content of bios the pci-part of chipset isn't initialized
2. maybe onboard video is bad
P.S. There are two different bios versions for PB450: for ISA model and for PCI model.
I don't know what it means 😀 Is it about the riser or videocard or chipset? Can you upload high res photos?
Reply 7 of 189, by ahtoh
Yes I changed J17 back to normal operation of course. I flashed bios for ISA system.
Onboard video is based on CL-GD5428 chip and it is VLB AFAIK
Unfortunately, I have no spare ISA graphics card so I can not verify if it's the graphics card that is faulty.
a few photos attached
    265.54 KiB
    379.69 KiB
    293.62 KiB
Reply 8 of 189, by bjwil1991
Post pics of the motherboard and the whole PC so that way everyone can help you out with the issue. Does the monitor work with another computer?
Reply 10 of 189, by bjwil1991
Remove the jumper (J33) by the PC Speaker (LDEV bypass) since it looks like it's enabled and see what happens.
Reply 12 of 189, by bjwil1991
I see you don't have a riser card installed. Was it installed previously? Also, put the jumper back in. The LDEV Bypass is used for ISA slots.
LDEV Bypass
Enabled --> ISA
Disabled --> PCI
Reply 13 of 189, by Roman555
And what about J9 (Video IRQ enable) ? Should it enable or not by default? It's different in different sources.
Reply 14 of 189, by bjwil1991
On my motherboard, mine is disabled since the MPU-401 card I have uses IRQ 9, but, it varies.
Sources:
1) http://www.uktsupport.co.uk/pb/mb/450.htm
2) http://www.arvutimuuseum.ee/th99/m/P-R/33546.htm
Enabling it should make the system boot up without issues.
Reply 16 of 189, by bjwil1991
How's about J20 (I/O)? Is that set to enable (pins 2-3) or disable (pins 1-2)? Maybe the video BIOS went out on there. I can dump the BIOS contents for you in case you need it. Do you have an EEPROM programming tool? If not, I can make the BIOS chip for you.
Reply 17 of 189, by ahtoh
Tried to disable J20 - no change. Two beeps.
I don't have any EEPROM programming tool, and I'm not able to locate video bios chip on this board.
I suspect it is in the square chip n82c42pe (shown in the first photo above)
I will still probably be able to replace the chip but don't want do mess with it until I'm sure it is the cause of the fault
Reply 19 of 189, by bjwil1991
That's my guess, too.
