First post, by tegrady
- Member
Hi, I have an Amptron PM-9100LMR aka PC Chips M571LMR v5.1 Socket 7 motherboard.
It currently has an AMI bios dated 03/09/2000S.
The full bios name is 62-0309-001437-00101111-071595-M571-10000000-H.
I want to update the bios so that it will accept a Pentium P55C MMX 233.
According to
http://cwcyrix.duckdns.org/techpage/html/m1.html, the most recent BIOS for the v5.1 board is dated 07/04/2001.
I downloaded the 07/04/2001 BIOS and tried flashing it using the AMI Bios Flash Utility, but got the error "BIOS file size and detected Flash EPROM size does not match".
I then tried UNIFLASH, but got the error message "Warning: Bootblack Mismatch!! Proceed Anyway (Y,N)?" I then tried the advanced feature and used the 'flash bios image including bootblock'. I then got the error message "Waring: About to Alter the Boot Block, Proceed (Y,N)?".
My questions:
1) Is the 07/04/2001 the correct bios image to flash?
2) should I ignore the UNIFLASH warnings and alter the boot block?
I don't want to brick this board.
Thanks.
