Reply 8860 of 27455, by Thermalwrong
I got my cheap Packard Bell 486 system up and running, with Windows 95 on it - the seller packed it in cardboard without any padding at all, so the front and side plastics arrived damaged 🙁
So far, I've repaired the side plastic because it was getting caught all the time, but the front plastic is still broken, which is thankfully not too visible from the front.
I cleaned some rust off of the back of the case using the dremel, but there's still rust on quite a lot of the computer, still, not structural or visible 😁
The hard drive(s) it came with were either broken or had loud enough bearing noise that they really should be, so I've been running it from floppy disks intially - the noisy 500mb hard drive does actually read, but doesn't boot up Windows, so I'll have a look at that later. First I want a clean install of Windows 95. The drive support on this computer is around 2GB, so now it's got a 2GB CF card fitted to the VLB IDE channel:
The original CD-ROM drive has been swapped out for now because it's a very old Panasonic CR-563 which requires the sound card to operate as the controller and I don't really want to deal with the drivers for that. So that's replaced with some generic CD writer (not period correct at all) which goes on the second IDE channel.
Windows 95 installed quickly enough, but it was failing on this screen with both 16MB SIMMs fitted, so now it's got just the 20MB of RAM:
It's got a Packard Bell 450 motherboard, with:
Cyrix / ST 486 DX2-80 (running at DX2-66 speed)
0KB L2 cache
20MB of RAM (4MB onboard) and possibly only one working memory slot of the two
Cirrus Logic 1MB video
Aztec sound card with OPL3 - this works really nicely, though the computer must have had powered speakers originally because there's no headphone port, only line-out
Transcend 2GB Compact Flash - 300x UDMA
The monitor doesn't really look period correct, but I like it better than an LCD for this machine. I like that the replacement CD-RW is so yellowed that it matches the casing too.
I need some L2 cache for this machine, this is slower than I remember my old 486 being, I'm amazed that it was sold with none fitted. I was given an AMD 486 DX4 100 chip years ago which has been sitting on my desk at work - I'd really like to see if it works or not, but this motherboard is 5v only, so now I'm tempted to look into what it would take to add in a step down DC to DC circuit like this to it, since it has jumpers on the board for 3.3v operation, but no voltage regulator fitted.
