First post, by Changrey
Hi, I just started using DosBox and don't really know much about it.
I'm trying to get an old Win98 game (X-Com Apocalypse) to run, but it can't switch to the directory.
I've mounted the game folder as C: and can switch to the C-drive just fine (in DOSBox), but when I try to activate the folder with the 'cd XCOMA' (XCOMA being the name of the directory specified as C-drive) command I just get a "Unable to change to: XCOMA"
Going by the Pictorial guide in the DOSBox guide forum, I should be playing and messing with the CPU cycles and whatnot... So, any idea why I can't access the folder? The entire process have been followed to the letter in the Pictorial guide.
Here's my specs in case it helps...
WinXP Pro
AMD Athlon XP 1500+
1.3Ghz
768 DDR RAM
Radeon 9600Pro Sapphire graphics card
[/i]
