First post, by sf78
The rig:
P180 MMX
64Mb
4Mb Tseng ET6000
The Problem:
The game often ends up being a completely unplayable slideshow, even on lowest resolution. I don't remember other Duke engined games being this bad as I certainly didn't have anything this powerful back in the day and throughly enjoyed Shadow Warrior etc. I tested it on a K6 200 and it seemed to be the lowest possible way of running it properly. I'd rather not make another DOS build from the K6 if I can avoid it, so any tweaks I could try?
Reply 1 of 4, by derSammler
P180? Is that a Pentium Pro? There was no P55C with 180 MHz to my knowledge.
Redneck Rampage runs perfectly fine on my MMX 200 MHz in SVGA. In VGA, it's smooth even on my DX4/100.
What OS are you running?
Reply 2 of 4, by firage
P200 MMX on a 60MHz bus, I guess.
My big-red-switch 486
Reply 3 of 4, by leileilol
Could be this
Debian's fucked
Reply 4 of 4, by sf78
And you are right, it's an overclocked 166.
