I had chosen wider connector separation so that input connectors would be slightly further away from output ones. I also made the holes oversized a bit allow for some slack (and to accomodate both raised and lower TRS connectors, though not completely sure it works for the lowered ones very well).
I'll work on a revision of the bracket shortly, 640K!enough sent me a few files that show the supposed dimensions ~
firage wrote:That's still missing the PCB screw mounting part, or will it hang off the MIDI port screws like keropi's MPU cards?
Yeah, I see that's just the way of existing Yamaha based designs...
I don't see any point in having the screw on top, more often than not I have to remove it to make the card fit properly in most chassis' I have. So yes, GamePort will hold the bracket in place.
In other news, I fixed two DB60XG modules I have that both went silent at some point. The DAC+ADC chip had given up on both. I could see lot of activity on I2S lines in relation to what music was doing but no sound came out. End result was using the same DAC as I do on my card for YMF721, and result is very nice without any hiss to complain about 😁
I'll provide a few recording utilizing the WB header soon too, and possibly a video.
EDIT : Recording has been made and added to the playlist : https://soundcloud.com/tiido/sets/recordings-from-t-04ybsc
EDIT2: Small error in SETYMF got fixed, I wasn't properly reconfiguring YMFDEC when changing YMF721 settings.
