DOSBox ECE (for Windows & Linux)
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: DOSBox ECE (for Windows)
Postby KainXVIII » 2018-7-19 @ 08:54
Dosbox 0.74 vanilla - overlay works, but its glitched when it try to disappear (alt+enter will help), like on your video. I think that same behavior was with old ScummVM, not it works alright too.
Dosbox 0.74 svn (comes with AR) - overlay works without disappear glitch (yay!)
User avatar
KainXVIII
Postby Yesterplay80 » 2018-7-19 @ 11:57
So Steam either compiled a fixed version themselves or they're using an older version, that works better with overlays than the recent ones. Does the version of SDL differ maybe?
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby KainXVIII » 2018-7-19 @ 13:18
Yesterplay80 wrote:So Steam either compiled a fixed version themselves or they're using an older version, that works better with overlays than the recent ones. Does the version of SDL differ maybe?
SDL version in vanilla dosbox - 1.2.13
SDL version in Alien Rampage dosbox svn - 1.2.14 (but it does not have any copyrights on info page, maybe its indeed custom modified)
SDL version in ECE build (which does not show overlay at all) - 1.2.15
User avatar
KainXVIII
Postby Yesterplay80 » 2018-7-19 @ 14:23
Could you, just for fun, try to run the game using DOSBox ECE, but with the SDL.dll supplied with the game (1.2.14)? I'm not at home atm, so I can't try that myself.
User avatar
Yesterplay80
Postby KainXVIII » 2018-7-19 @ 14:39
Yesterplay80 wrote:Could you, just for fun, try to run the game using DOSBox ECE, but with the SDL.dll supplied with the game (1.2.14)? I'm not at home atm, so I can't try that myself.
I tried, still same result - overlay not showing up :confused:
User avatar
KainXVIII
Postby Qbix » 2018-7-19 @ 15:24
how about the build I linked you, with the SDL.dll of the game ?
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby KainXVIII » 2018-7-19 @ 15:34
Qbix wrote:how about the build I linked you, with the SDL.dll of the game ?
With your build and SDL of the game - overlay works, but disappear glitch persist.
User avatar
KainXVIII
Postby Yesterplay80 » 2018-7-19 @ 18:15
KainXVIII wrote:With your build and SDL of the game - overlay works, but disappear glitch persist.
Strangely, the exact same thing happens here on my PC with ECE and vanilla, too. So it seems to work "normally".
Can anyone else confirm these problems only occur with ECE?
User avatar
Yesterplay80
Postby Crimson_Zero » 2018-7-22 @ 01:59
I'd like to thank you for compiling DOSBox ECE. Your build actually allows Lands of Lore 2 to be playable in glide mode when using the teleporters. With other builds, I've had to switch out of Hardware acceleration mode to use them and then switch back again. It's fantastic to have a build available that is up-to-date with some great features!
*If you read the earlier post with the bug report, please ignore. It was user error*
Thanks again!
Crimson_Zero
Postby osmanvielma » 2018-7-30 @ 14:02
Spaz wrote:In Hoyle 3 you can bypass this problem by starting the game with: SCIDHUV -fw 0 0 200 320. Use lower case on -fw or you will get an error message.
Tested with a few other SCI games and they seem to work OK (Eco Quest and Castle of Dr. Brain)
Can somebody please tell me what those command line switches actually do?
And a list of command list available?
In castle of Dr. Brain there is this possibility of using scidhuv -f, but I don´t have a clue of what this could do.
I´m really curious about these switches. Any documentation regarding the use of these?
Thank you
User avatar
osmanvielma
Postby brad86 » 2018-8-09 @ 11:26
Hi guys.
Is there any way of getting Reshade to work with ECE?
I use the recently ported CRT shaders on various emulators and would like to try my Lottes VGA preset on dosbox.
Unfortunately, no matter which api I choose on the Reshade install, nothing shows up when playing. Even when changing dosbox graphics output from pixel perfect to OpenGL.
User avatar
brad86
Postby Yesterplay80 » 2018-8-09 @ 21:19
brad86 wrote:Is there any way of getting Reshade to work with ECE?
ReShade only works with DIrect3D, so no.
User avatar
Yesterplay80
Postby brad86 » 2018-8-10 @ 03:48
Reshade works on D3D9,10,11, and openGL
User avatar
brad86
Postby Yesterplay80 » 2018-8-10 @ 14:34
brad86 wrote:Reshade works on D3D9,10,11, and openGL
Oh, the last time I used it I recall it supporting D3D only.
It works here, here I applied a CRT and a Nightvision effect to DOSBox ECE running ROTT:
User avatar
Yesterplay80
Postby Dagar » 2018-8-11 @ 18:24
DOSBox ECE and Reshade works good here.
DOSBox ECE and Reshade with the CRT filter set up properly looks really, really good.
I noticed that you can't go over Brightness 0.600, and Gamma and Monitor Gamma over 2.000 or else the Reshade GUI overlay will not disappear properly and color glitch.
That issue is a problem of Reshade, not DOSBox ECE but I thought I'd mention it.
Dagar
Postby brad86 » 2018-8-12 @ 15:53
All good now. Not sure if it was my older version of Reshade or how my preset was done.
Now using the latest version and everything is working.
Thanks guys.
User avatar
brad86
Postby lukeman3000 » 2018-8-18 @ 07:09
Hey Yesterplay -
With r4134 I seem to be getting a strange sound glitch as seen here. I tested with vanilla DOSBox (v 0.74) and did not experience this (nor did I with previous versions of ECE) Any ideas?
Also, here is my DOSBox conf file if needed.
lukeman3000
Postby Qbix » 2018-8-18 @ 07:22
Just wait a little bit.
The problem is known and a solution exists, waiting to get it pushed to the right locations
User avatar
Qbix
DOSBox Author
Postby Delfino Furioso » 2018-8-24 @ 15:40
Dagar wrote:DOSBox ECE and Reshade with the CRT filter set up properly looks really, really good.
I've decided to give ReShade a try...
Do you mind sharing your config params for the CRT filter?
Thanks
Delfino Furioso
Postby Danfun64 » 2018-8-24 @ 16:24
lukeman3000 wrote:With r4134 I seem to be getting a strange sound glitch as seen here. I tested with vanilla DOSBox (v 0.74) and did not experience this (nor did I with previous versions of ECE)
Since a new version of ECE hasn't been released yet, and since I don't know if the fix for this issue has been committed to the regular dosbox repository, what was the last version of ECE that didn't have this problem?
Danfun64
PreviousNext
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 0 guests
