First post, by FeedingDragon
Some of the magic smoke escaped from my MB 🙁 In looking for a board that has an i82371 or i82801 southbridge (for SMB.exe,) as well as all the other requirements to get my system back up & running, I came across a FIC VB-601. Does anyone know how it responds to the PL-iP3T adapter and a Celeron 1400/100/256 processor?
Though, it turns out I may not need a MB anyway (smoke seems to have all come from fried speaker wire.) Just discovered a surface mount cap on my Voodoo 3TV that was half off (now is fully off, see pic.) Something must have happened during one of the many moves I had to make over the last couple of years 🙁 Right now, the system is booting with a temp AGP video card & PSU. More testing to come.
The PSU is definitely bad, it won't turn on when the button is pressed. I had double checked the connections, and plugged it in to try again when the system tried to start up (without pressing the power button,) and the speaker wire started melting & smoking 🙁 Have a PSU I'm borrowing from my 3.2 Ghz Core Duo system (which I had been trying to sell till now.) Really overkill, but it will allow me to test the system out & make sure nothing is broken.
Finally, anyone capable of repairing a V3 with this problem? Barring that, I'm going to need to either get a replacement V3 or find an alternative graphics card that has drivers for Windows 3.1 (yes, 3.1.) I went through several before I got to this Voodoo card, and all had one problem or another. Sort of like to find one that is 100% VESA compliant as well, if that is possible.
396.83 KiB
Broken Voodoo 3 capacitor
Feeding Dragon
Reply 1 of 7, by The Serpent Rider
Pretty much any local workshop can fix surface mounted capacitor.
Reply 3 of 7, by cyclone3d
Looks to me like the pads are off.
Also looks like the traces are on the same side of the board, which is definitely a good thing.
Just have to expose the copper in the traces and then solder to them.
Pretty easy fix.
Any repair shop should be able to fix that in a few minutes if you don't want to solder it yourself.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 7, by FeedingDragon
With my tremors, no way I could do that, and Waco doesn't appear to have any form of workshop that does that kind of work 🙁 A couple of place have someone willing to do soldering work, but only basic stuff.
Feeding Dragon
Reply 6 of 7, by cyclone3d
Well, if you don't mind paying for shipping both ways, I should be able to fix it. Send me a PM and we can discuss.
YMF7x4 Guide
Reply 7 of 7, by nforce4max
You can bodge it and any repair shop is going to do the same thing anyway, as for central Texas I have a deep loathing for this place.
