First post, by ruthan
Hello,
i was played Quake 1.. and as im becaming more and more greedy with every new technology upgraded.. i started to be disappointed by sound quality, when game is starting there some its about SB setting and that rate 11025 is used? I never understood sound too much, but as i understand it, more is better.. and some Dos games has rate up to 44KHz.
I could get Quake sound info through soundinfo and sbinfo command, here is 11025 for me, maybe is because that im emulating too old SBpro2 by Yamaha driver SET Blaster.. I tried to find any console command / variable to increase quality, but i have failed..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1 of 5, by leileilol
-sspeed 44100
FUCK "AI"
Reply 2 of 5, by ruthan
Thanks its working fine.
Reply 3 of 5, by Azarien
That changes mixing quality, but the samples themselves are still 11025 Hz only...
Reply 4 of 5, by leileilol
There's a few 44khz sounds in there. Fire a thunderbolt at some fish.
FUCK "AI"
Reply 5 of 5, by DracoNihil
You can also download QTEST1, extract *some* of the WAV files from that and use those as drop-in replacements on retail quake.
Though the nailgun can't be replaced this way as they sound very different in QTEST1.
― Κυνικός Δράκων
