First post, by Slot1
I scored the board for 9 bucks on ebay 😀 , with 1ghz pentium 3 and the heatsink attached. Sadly, i just found out that on the back of the northbridge there is a component missing 😢 (marked as C280). I've attached the photo. Can anyone identify the component? I can probably fix it for one buck and solder it back on but i can't identify it, no information online either. I'm planning on pairing it with a Voodoo5 5500 and a Diamond Vortex2.
    1.82 MiB
    Northbridge
Reply 2 of 2, by Slot1
Thanks! I didn't expect an answer that quick. Now only thing is to identify the color. I'll search for images online for that. The model i have is with no onboard audio. Here are some images. I'm planning on adding both the Vortex2 and SB!Live with the Drive II. I'll post some pics in few weeks when i complete the build. I also got the Lian Li PC-7 case.
    701.96 KiB
    1 MiB
