Reply 24540 of 57475, by kixs
bjwil1991 wrote:
That's amazing picture quality for a high-end CRT. Is that from the early 2000's? I have a Medion MD 1998 OF 19" CRT from the late 1990's early 2000's that can output 1600x1200 at 120Hz maximum.
I think we already had this discussion... it's not possible even for the high end monitors.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 24541 of 57475, by amadeus777999
The problem with rate and resolution on CRTs is that the higher each goes, the blurrier the picture.
Unlikely also because the P260 has vertical max- frequency of 121khz and 1200lines at 120hz need a 144khz capable screen. There's also some overhead needed so it would be even higher than 144khz.
Reply 24542 of 57475, by Predator99
Puh...as I saw this offer I was unsure if I should buy this pile for 130€ shipped as the photos were rather bad:
The attachment x6.jpg is no longer available
It arrived today in a big box. It was further damaged during transport and the boards already came out of it at the bottom 😵
But...what I got is incredible. Several XT boards - some of them IBM - 286, 486 and many IBM ISA cards. Then several up to date ASUS boards with CPU+RAM which I belive to be much faster than my current main PC. However, all in bad condition with soil on it but I think almost the XT-486 stuff should be fixable.
Maybe will post detail photos the next days...
Reply 24544 of 57475, by Predator99
No nothing. Scrap lot as described. Would like to know if the seller had the complete PCs...if yes, he wasted lots of money.
Reply 24546 of 57475, by Predator99
So most intersting for me:
Chips 80286:
The attachment IMG_9855-r.jpg is no longer available
Schneider EURO PC XT
The attachment IMG_9856-r.jpg is no longer available
JUKO ST XT
The attachment IMG_9857-r.jpg is no longer available
Chips 80286
The attachment IMG_9858-r.jpg is no longer available
IBM XT
The attachment IMG_9859-r.jpg is no longer available
Reply 24547 of 57475, by Predator99
Also IBM XT?
The attachment IMG_9860-r.jpg is no longer available
80486...what kind of connector is this above the memory slots? Never seen...
The attachment IMG_9861-r.jpg is no longer available
And the ISA cards:
MDA/CGA?
The attachment IMG_9862-r.jpg is no longer available
MFM and CGA with Cinch:
The attachment IMG_9864-r.jpg is no longer available
Octek Trident VGA and some kind of IO card:
The attachment IMG_9865-r.jpg is no longer available
Reply 24548 of 57475, by Predator99
CGA and a EMS card? 3rd one for me, hopefully I get it running this time...
The attachment IMG_9866-r.jpg is no longer available
MDA or CGA, MFM and VGA
The attachment IMG_9867-r.jpg is no longer available
Reply 24549 of 57475, by Pabloz
now thats what i call retro
Reply 24550 of 57475, by stamasd
That second Chips 80286 has some screwed-up memory chips. That board has taken some serious physical abuse.
And, the "Also IBM XT?" is in fact a IBM PC motherboard.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 24551 of 57475, by yawetaG
It may be used to connect various types of riser boards and in some cases additional system boards. Does it say anything on the back of the board? Also interesting it includes a soldered 486DX and also has an upgrade socket...
Edit: Ah, maybe the socket is to add an additional processor board, and the system was an industrial one with one or more processors (which would explain the additional socket)?
Reply 24552 of 57475, by Predator99
You are right...its the Original 1981 PC board!!! Was only a quick&dirty asigment by me without google...
Contacted the seller gain yesterday. He has another lot with interesting boards. He told me that he got everything from a e-waste bin. I asked him if also the cases were in it but no reply yet...
Yes I am aware everything is damaged and quite dirty. Will clean and fix before testing it. But not much time at the moment.
Reply 24553 of 57475, by Predator99
Oh interesting. Will take a look if I find a suitable card in the pile. The 486 is on a socket. Board is labeled "486-33.256kBC..ISA.MITAC.ABC m433c22" and "A4865/A4866-XX V2.1 COMP".
Reply 24554 of 57475, by derSammler
That I/O card is the original IBM 5150 floppy controller.
Reply 24555 of 57475, by Predator99
argh...this means the seller most probably had the complete PCs and disassembled them 😵
Hopefully he can also get the cases. But if yes, would be rather difficult to ship to me and I am running out of space...
Reply 24556 of 57475, by derSammler
Got some more goodies for my Matrox Mystique today. 😀
Reply 24557 of 57475, by PTherapist
Predator99 wrote:
Chips 80286
2nd one
That's cool, I have near enough the same motherboard with just a few differences such as the colour, jumper pins over by the battery & a row of resistors instead of those orange coloured chips for example. The CPU in mine is an Intel 286 10MHz overclocked to 12MHz and it has 1MB RAM.
Reply 24558 of 57475, by stamasd
I don't think the 486DX is soldered. If you look closely you can see a tiny bit of a socket underneath it. And the extra socket is for a Weitek 4167 coprocessor (PGA142).
That extra slot's connector looks suspiciously like the one used on Mac IIs for the NuBus expansions. Of course that doesn't mean the board has NuBus, but these connectors were commodity hardware during that time.
(edit) there are also a lot of damaged capacitors on that 486 board, especially near the coprocessor socket. I would replace them before trying to power up that board.
I/O, I/O,
I/O, I/O
Reply 24559 of 57475, by yawetaG
I was just guessing, TBH. The only other place I've seen the kind of connector that's above the memory slots is on certain Japanese systems where the motherboard is basically build out of modules that can be swapped for different configurations.
What would be the use for a co-processor on a system that already uses a DX processor?
