First post, by Danfun64
IPXNET is, of course, limited to DosBox; Kali and Khan seem more or less dead; I don't know how to configure PPTP (and I am under the impression that I'd have to open ports on the server hardware, which might not be possible...)
So... how do you connect real hardware ipx through the internet in 2018?
The reason why I'm asking is so I can run doom2.exe (NOT Chocolate Doom or similar) on real hardware and/or low level emulation (NOT Dosbox... at least not without booting a guest os and using an ne2000 patch) using XTTL's modified IPXSETUP from here (NOT a Doom TCP/IP Driver).
