Reply 24740 of 57169, by bjwil1991
jheronimus wrote:
- some noname multi I/O […]
I had that type of I/O card from 1994-2012. The one chip on there is a Winbond (cannot remember the model number), and it's a pretty good I/O card. Also, great haul as well.
Reply 24741 of 57169, by oeuvre
bjwil1991 wrote:
oeuvre wrote:
Ordered an Optiplex GXa the other day. I'm trying to figure out what sound card this is... my guess is a CT1600. […]
My guess is the Sound Blaster CT1350B.
It turned out to be a CT1790 SB16... with YMF262 chip.
Reply 24742 of 57169, by cyclone3d
Just picked up this lot:
The attachment lot.jpg is no longer available
In the upper right hand corner... a Logitech Soundman Wave and an ATI Mach32 VLB 😀
The attachment soundman_wave_mach32_vlb.jpg is no longer available
In the bottom middle, I think that is a LBA BIOS card for supporting larger HDDs.
The attachment LBA.jpg is no longer available
I'll probably try to sell most of the cards except those 3 in order to recoup the cost.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 24743 of 57169, by TheAbandonwareGuy
cyclone3d wrote:
Just picked up this lot: […]
I have the install floppies for a Soundman Wave (and about 20 other early sound cards) but I'll never be able to own any of then thanks to scalpers and power buyers.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 24744 of 57169, by matt.c
I think I did really well over the past weekend. I found a new in box Wave Blaster II. It is marked "GP-1910" with a sticker, but I imagine it's a standard CT1910 inside.
The attachment IMG_20180815_220919 (2).jpg is no longer available
I've given a pretty decent go at finding information about this particular SKU, and the only images I can find only of it is a super low-res photo from an old QVC.com listing.
I haven't opened it - yet - as I don't really foresee using it. However, I did scan the box for posterity.
The attachment GP1910-CT1910-front.jpg is no longer available
The attachment GP1910-CT1910-back.jpg is no longer available
The attachment GP1910-CT1910-left.jpg is no longer available
The attachment GP1910-CT1910-right.jpg is no longer available
Reply 24745 of 57169, by cyclone3d
@TheAbandonwareGuy
Ehhh.. Somebody posted up that lot and didn't really know what they had. I also gave a "best offer" and they accepted.
Most of the more rare stuff I have, I have gotten for pretty cheap.
You just have to keep an eye out for good deals.
I've accumulated tons of duplicates of a lot of cards without even trying. I am going to be thinning out the duplicates (most not rare cards) in the not too far future.
YMF7x4 Guide
Reply 24746 of 57169, by badmojo
Not sure what you're trying to achieve with this whinge campaign - so you can't afford stuff, what do you want us to do about it? Man up and accept it or find something within your control to get angry about.
Reply 24747 of 57169, by DaveJustDave
had another nice haul today, and came across this. Orchid TurboEGA.. never ever seen one of these in the wild before. ribbon cable goes down to the CPU socket on a 5160. Card has an ~8mhz 286 cpu + original 8088 (you can toggle it for compatibility) and an 287. integrated EGA and some cache memory.
The attachment 20180815_220403.jpg is no longer available
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 24748 of 57169, by Batyra
@cyclone3d - nice lot! especially with that soundcards!
@matt.c - very nice find! Don't open it! NEVA! 😀
Reply 24749 of 57169, by jesolo
matt.c wrote:
I think I did really well over the past weekend. I found a new in box Wave Blaster II. It is marked "GP-1910" with a sticker, bu […]
Nice find - I bought one a couple of years back but, it only came with Nascar Racing.
Would be interesting to know which "special" versions of those games are on that CD. I imagine just the Shareware versions.
Reply 24750 of 57169, by luckybob
@davejustdave
that cable is more valuable than the actual card.
Reply 24751 of 57169, by 0kool
Never owned a Matrox and since I already have a dedicated DOS machine with S3 Virge, I've decided that one decelerator is quite enough 😀. Might be not that exciting for many here, but I couldn't be happier.
The attachment 2018-08-14 09.07.59.jpg is no longer available
The attachment 2018-08-14 09.08.50.jpg is no longer available
Received this beauty a few days ago in the original OEM package. Was listed as Mystique 220, but I can't find any labels to confirm (that it is not a 200). Will pair it with Diamond Monster 3D 4mb in 233MMX.
Reply 24752 of 57169, by stamasd
0kool wrote:
Never owned a Matrox and since I already have a dedicated DOS machine with S3 Virge, I've decided that one decelerator is quite […]
Based on part number (644-00) model number (MYST/4G) and info from http://www.512bit.net/matrox.html and http://www.vgamuseum.info/index.php/component … sg-mystique-220 it probably is a Mystique 220 4MB.
(edit) the chip is MGA1064SG which is from the original Mystique, not Mystique220 though. Maybe Mystique factory-overclocked? There is a card with this chip listed as Mystique220 on the second page I linked above. But then again there are 2 cards identical to yours at http://www.vgamuseum.info/index.php/cards/ite … 1064sg-mystique that are listed as Mystique (not 220).
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 24753 of 57169, by DaveJustDave
luckybob wrote:
@davejustdave
Can you elaborate/share what you know about these cards? I actually had no idea they even existed. Its really one of the more interesting finds I've come across.
Reply 24754 of 57169, by stamasd
My Alpha streak continues. Aspen Systems Inc. Telluride motherboard, for Alpha AXP21064A CPUs, 7PCI/2ISA (1 shared), full AT size, can take single or dual AT power supply, has FDC but no HD controller. It's a pain to find information about it.
I found some info at https://web.archive.org/web/19961029101526/ht … tellihpiee.html and the jumper config is in TH99 http://arvutimuuseum.ee/th99/m/A-B/33199.htm . It does come with 4x1MB proprietary cache modules.
I/O, I/O,
I/O, I/O
Reply 24755 of 57169, by liqmat
stamasd wrote:
My Alpha streak continues. Aspen Systems Inc. Telluride motherboard, for Alpha AXP21064A CPUs, 7PCI/2ISA (1 shared), full AT siz […]
Boy, that is a very clean engineered board. It's so tidy!
Reply 24756 of 57169, by xjas
^^ Nice. Since we're talking about Alpha stuff, two DEC 3000-400 AXPs popped up awaiting disposal in one of my usual picking spots. These are 133MHz machines, 64-bit.
The attachment 1-sized.jpg is no longer available
The attachment 2-sized.jpg is no longer available
The attachment 3-sized.jpg is no longer available
The attachment 4-sized.jpg is no longer available
...Cool looking boxes, but I left them there. 🙁 I have no real interest in messing with this platform or VMS, and these seemed REALLY heavy for their size (and they're not small!) I hurt my wrist in a bike accident a couple weeks ago and had trouble even picking one of them up. Can't take it all.
Reply 24757 of 57169, by stamasd
xjas wrote:
^^ Nice. Since we're talking about Alpha stuff, two DEC 3000-400 AXPs popped up awaiting disposal in one of my usual picking spo […]
🤣 those were factory underclocked. The slowest Alpha made was 150MHz, the 21064-AA. According to the system manual http://paleoferrosaurus.com/documents/Alpha_S … XP/d3syspmb.pdf it's indeed the 150MHz AA chips that were used in those, clocked under specs...
I/O, I/O,
I/O, I/O
Reply 24758 of 57169, by dionb
Now I'm getting jealous 😉
The Alphas I had were absolutely huge, always wanted a nice little one. A Multia would be best (or one of stamasd's ATX boards), but something that could pass for a regular desktop PC (at least until you try to lift it) would be a lot better than nothing. My wrist's also a bit weak after slipping on the stairs recently damn, this sort of accident makes you feel old but where there's a will, there's a way.
Tomorrow I hope to post something pretty nice here too, so can't complain. It should be worth the 4-hour round trip. At least I really hope so 😜
Reply 24759 of 57169, by debs3759
I would have snapped that up if I collected non x86 stuff still. Lovely board for a nice price from the most reliable source I know 😀
