That's quite a haul! And I agree, that Acer looks excellent, is the boot menu just an autoexec menu?
Today, I got an AT case, which was sold as just a PC chips motherboard, so it's not like I can complain to the seller about this - but the case is fairly badly damaged.
Three and a half of the screw posts are snapped off and there are two other broken bits of plastic. The plastic motherboard standoffs are broken and some of the RAM is half out of its slots? This case had a rough trip 🙁
The attachment marcus1.jpg is no longer available
I'm gving this method a go - dangerous smelling plastic solvent glue from Wickes, it's apparently Methyl Ethyl Ketone based but much less fluid, seemingly it has a bit of plastic in the solution:
The attachment marcus5.jpg is no longer available
I used a lot of this stuff, I guess I will find out very soon whether that's a good idea or not...
The attachment marcus3.jpg is no longer available
This split on the side proved very difficult to hold in place - I have another case with similar damage so I'm really hoping this glue bonds when clamped like this
The attachment marcus6.jpg is no longer available
Edit: This worked really well! The broken off pieces of plastic are now securely back in place and with it sanded down, it's very hard to tell there was a crack there at all.
I'm not 100% sure the screw mounts are very solid, but that's less of a big deal because there are secondary pegs there that can fit screws.
