Reply 24840 of 52967, by Thermalwrong
That makes sense given the speeds fans from 90s / early 00s PCs run at and the relative quality of the materials / design, fans are technically a wear item 😀
Reply 24841 of 52967, by evoportals
I didn't buy this but I found it in my parent's basement when I helped them move recently. I was shocked to see it. My parents bought my brother and I this back around 1994 or so for our 386 PC. I remember the price was $150 😳 It later went into a 486. In 1999 we did a major upgrade to Pentium 3 and this card was buried in their basement since then.... until now 😁
171.7 KiB
Reply 24842 of 52967, by bjwil1991
You lucky dog. That's amazing quality sound right there.
Reply 24843 of 52967, by cyclone3d
Sweet find!
Would have been even better if it was the dual OPL2 version.
Still really cool that it is still around and you even have the box.
As for me, I received a box of unknown ISA cards today and the only really good card in there was yet another TSENG ET4000AX card.
The rest were all modems and network cards and a single Mitsumi CD-ROM controller card.
Worst box of random box of cards I have gotten by far... at least it wasn't a total bust.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 24844 of 52967, by schlang
the dual OPL2 is only supported by a very small amount of games - and all of them are from an area where they have GM/MT32 support so there is absolutely no benefit
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 24845 of 52967, by amadeus777999
Got an ASUS P5A-B with an above average 233MMX which seems capable of running 300@120x2.5(speedsys is a bit out of the loop here). I have to test the setup more thoroughly though.
Pretty cool, but bus speeds are not that fancy when compared to 83mhz boards.
    104.74 KiB
    610.65 KiB
Reply 24846 of 52967, by dionb
I once ran a P233MMX at 3.5x100MHz on a DFI MVP3 board accidentally. I'd previously had a K6-2 550 installed and forgot to adjust the FSB. So given the first two multiplier bits (which the P55C understands) are the same for 5.5x as for 1.5x/3.5x, it was set to 350MHz. And it ran. Happily. At stock voltage. And stable. It also felt a bit quicker than a K6-2 350 I had had earlier, but this was in UT99, which is FPU-intensive, so that's no surprise.
Reply 24848 of 52967, by Batyra
Some recent boughts.
Sound Blaster CT1320C (without CMS) - luckily I have second with CMS chip.
86.64 KiB
Roland RAP-10 some different package
Afaik there were three options - one "production", two - blue one and this plain white as third - do you know any other?
90.07 KiB
Roland RAP-10
(sellers photos)
Reply 24850 of 52967, by amadeus777999
350 is pretty astounding! All 166/200/233 are easy to overclock to a certain extent but, clockspeedwise, a wall is soon confronted... thus 350 being really unique.
I like the MMX cpus when compared to the K6 as latter always had that "hot air" feeling to it.
Reply 24851 of 52967, by DaveJustDave
interesting! for some reason, deep in the recesses of my memory, I always thought the RAP-10 was a drum machine. How's it compare with the LAPC/SCC?
Batyra wrote:
Some recent boughts. […]
(sellers photos)
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 24852 of 52967, by Cyrix200+
A large-ish lot of old cards showed up at the local Craigslist (Marktplaats). Even though I promised myself (and my girlfriend) to not buy any more 'crap', there were too many goodies in the picture. All tested and 'broken' though, so it might be a dud. But I paid 15 euros...
I love the Asus V3400TNT, even with the wrong heatsink. I bought one new back in the day and loved it 😀 If I remember correctly it should have a fan though...
FY3O2rel.jpg?1
And now the real good stuff:
gsADePXl.jpg?1
I hope I can get that CT1350B to work 😀
1982 to 2001
Reply 24853 of 52967, by moawkwrd
Picked these up today after winning an auction on eBay... for a whole £16. A Carrera PC Tower and Toshiba TekBright CRT monitor.
Gave the exteriors a quick clean but they need a proper going over as unfortunately they do smell a bit of cat wee 😵
Inside is pretty tidy and surprisingly clean. It's got a Pentium II MMX 350MHz, 256MB PC133 SDRAM, 4GB Western Digital HDD, Floppy, CD-ROM, a network card and these two:
No idea about these cards.
Booted into someone else's Windows first time... I checked the last time any files were altered - 2004! The monitor was a bit crackly at first, but it seems fine now.
Xeon E3-1241v3 - 16GB DDR3 - Vega 56 - W10
PII 450MHz - 256MB SDRAM - Voodoo 3 3000 PCI - W98SE
Reply 24854 of 52967, by krivulak
The real good stuff is the HDD. I have almost the same one in my museum, but not RLL and mine has headcrash. I envy badly 😁
Reply 24855 of 52967, by Cyrix200+
I want to test it, but not sure how yet. Any tips?
1982 to 2001
Reply 24856 of 52967, by KCompRoom2000
I've managed to snag a 3dfx Velocity 100/Voodoo3 8MB AGP video card for less than what they usually go for.
558.05 KiB
589.18 KiB
I haven't been able to test it since the few AGP 3.3V machines that I have are in use and my only spare motherboards (for now) are 1.5V only. The seller mentioned that it works so there's no rush in testing it myself. At least now I have another 3dfx card for my video card collection.
Reply 24857 of 52967, by bjwil1991
A motherboard that has a Universal AGP slot would suffice as well. I have a DFI KM266Pro-MLV motherboard that has a Universal AGP slot that works with 1x, 2x, and 4x AGP cards with no issues (which is surprising to me and I haven't seen a Universal AGP slot since the Athlon XP days).
Reply 24858 of 52967, by Murugan
Pls help me find this one boxed!!!!!
Was my first card and I am obviously looking in the wrong places for years 🤣 🙁
Do you need an XT for these drives to be able to test since it's pre-IDE or at least the controller? This looks like one in an XT clone I bought.
Reply 24859 of 52967, by The Serpent Rider
993.04 KiB
994.85 KiB
1.02 MiB
1x Radeon 7000 PCI 64mb
2x Radeon 7000 PCI 32mb
ASUS Vibra 16C
Wave Melody MF 1000 (ALS100+)
Duron Morgan 1000Mhz
Athlon Thunderbird 1133Mhz
Athlon XP 3000+
Good stuff.
