Reply 20 of 20, by tpowell.ca
tpowell.ca
Offline
- Member
Reviving this thread due to another oddity I discovered about this board (rev 2.1) where 512KB cache does not work using the jumper settings in the manual.
For a 4x 1024kbit chip configuration + 256kbit TAG I had to use:
JS1 2-3
JS2 2-3
JS3 1-2 --> NO JUMPER
JS4 1-2 3-4
Anyone else seen this issue?
Also, what are the proper CPU jumper settings for an AMD 5x86-133 ?
I used the "Intel P24D and AMD Enhanced Am486 Settings" from the manual with the JC8 jumpered to 2-3 to get the chip to 133MHz (quadrupled 33MHz).
Is this right?
- Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
