Reply 20 of 38, by realoldguy23
Vipersan wrote:
@ JidaiGeki Could you flip your board over and perhaps take a look/close up photo ..at the area around U510 ..? where I have mis […]
@ JidaiGeki
where I have missing components ?
rgds
VS
Did you notice that the images in post #4 are really very hires?
Right click on them and select "show image in another tab" and you can zoom in to your heart's content. What I can easily see there: U510 is a 74VCX08 which is a "Low Voltage Quad 2-Input AND Gate with 3.6V Tolerant Inputs and Outputs" (http://www.mouser.com/ds/2/149/74vcx08-289888.pdf). Resistor R548 and R542 aren't there. Resistors R549, R550, R551 are 0 Ohms (marking R00), Resistor R541 is 4.7kOhms (marking 472).
Reply 21 of 38, by stamasd
Ahh yes VCX08 makes more sense. It's a current production chip at OnSemi (they bought Fairchild a couple of years ago), you can order it direct with them if you have an account http://www.onsemi.com/PowerSolutions/product.do?id=74VCX08 but it's kinda not worth it unless you buy in bulk because the parts cost $0.20 and the shipping charges are $11 minimum.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 22 of 38, by Vipersan
Thanks for confirmation of the parts ..
but sadly ..I am having problems when I can't actually get a jewellers eyeglass in close proximity to a small physical object ..and illuminate it to my advantage ..
Yes ..my eyes are that bad ..
The MS I suffer with did the damage.
So all help is appreciated.
rgds
VS
Reply 23 of 38, by Vipersan
Ordered just 1 from Little diode ..
£3 no postage ..on ebay .
https://www.ebay.co.uk/itm/ON-Semiconductor-7 … OEAAOSw8hxbNlAL
worth a punt.
The zero ohms sm resistor can just be linked for now..
Reply 24 of 38, by stamasd
You need a "helping hands" stand; it's a heavy base with an attached magnifier and 2 adjustable clamps. Looks like this:
There are even some with integrated light and soldering iron stand like this one:
I/O, I/O,
I/O, I/O
Reply 25 of 38, by Vipersan
stamasd wrote:
You need a "helping hands" stand; it's a heavy base with an attached magnifier and 2 adjustable clamps. Looks like this: […]
Yep ..that is a useful item ..but I do have a good range of x10 >x20 eyepieces ..which make my hobby and by work still practical.
Thing is ..at distances over 2 foot I can still function well enough with glasses ..
..but I do find lighting from different angles beneficial ..and for that ..the item has to be actually there.
Photos help ..but no substitute for the real thing..
Reply 27 of 38, by stamasd
How about one of those USB microscopes connected to a PC? You can find them around $20. Example:
https://www.amazon.com/Jiusion-Magnification- … vZ0L&ref=plSrch
I/O, I/O,
I/O, I/O
Reply 28 of 38, by Vipersan
...Early Days yet ..
BUT ..looking promising ..in that the Voodoo 5500 PCI now posts ..
see pics.
The replacement glue logic chip arrived and was fitted..but not found any suitable zero ohm restors ..so just added a blob of solder as a link..
but ..to get this far gives me a warm glow..
not counting any chickens yet though..
rgds
VS
    311.83 KiB
    316.77 KiB
Reply 29 of 38, by Vipersan
I'm Obviously going to need drivers soon ..in order to test this beast..
There is just one voodoo 5 driver disc in vogons archive ..
does this one also cover the 5500 ?
I hope so ..cos I'm currently grabbing a copy..
rgds
VS
Reply 31 of 38, by Vipersan
Pretty sweet ...
All appears to be working
3Dmark 5704 13034
But only 512mb ram installed atm ..and no sound card ..
Just a bare bones 98se build to make sure the voodoo was working.
Looks like I have a winner.
Reply 34 of 38, by Vipersan
Just for completeness ..I figured I'd upload a photo of the repaired area..
    325.5 KiB
Reply 35 of 38, by canthearu
Using a solder bridge as a link isn't a problem really.
The main reason for using 0 ohm resistors is simply because they can be placed automatically by machine during assembly.
Reply 36 of 38, by stamasd
Very nice resurrection of a classic. Well done you lucky dog. 😀
I/O, I/O,
I/O, I/O
Reply 37 of 38, by Vipersan
Here is the result of the Voodoo 5500 pci in the system which will hopefully become my main retro gaming PC ..
The hope is to run both 98se and XP on pull out tray/caddy drives.
But of course I had to try 3Dmark 2001se ..
Of course not all tests can be completed or are indeed hardware catered for.
That said ..I am suitably impressed with what it _can_ do.
No Idea how the result benchmarks with similar systems..but I figure it has to be pretty good ..on account it looked good to me during the tests .
This is the system as is currently and the detailed result.of BlooDoo ....(yep thats what I've called the build 🤣 ...on account the tower is Blue)
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name
Registration Key
3DMark Version 330
DISPLAY
Platform Voodoo5 5500 PCI
CPU Optimization D3D Software T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate Default
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 1570
Game 1 - Car Chase - Low Detail 21.5 fps
Game 1 - Car Chase - High Detail 6.9 fps
Game 2 - Dragothic - Low Detail 24.7 fps
Game 2 - Dragothic - High Detail 8.0 fps
Game 3 - Lobby - Low Detail 41.5 fps
Game 3 - Lobby - High Detail 19.8 fps
Game 4 - Nature Not supported by hardware
Fill Rate (Single-Texturing) 343.5 MTexels/s
Fill Rate (Multi-Texturing) 584.4 MTexels/s
High Polygon Count (1 Light) 3.3 MTriangles/s
High Polygon Count (8 Lights) 1.2 MTriangles/s
Environment Bump Mapping Not supported by hardware
DOT3 Bump Mapping Not supported by hardware
Vertex Shader 11.7 fps
Pixel Shader Not supported by hardware
Advanced Pixel Shader Not supported by hardware
Point Sprites 0.8 MSprites/s
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family Duron(tm)
Internal Clock 952 MHz
Internal Clock Maximum 952 MHz
External Clock 100 MHz
Socket Designation Socket A
Type <unknown>
Upgrade Slot 1
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!
Version AMD Duron(TM)
CPUID 0x00000631
CACHES
Level 1
Capacity 128 KB
Type Internal
Type Details Synchronous
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 64 KB
Type External
DIRECTX INFO
DirectX Version 9.0
DIRECTDRAW INFO
DirectDraw Version 4.09.00.0904
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer 3dfx Interactive, Inc.
Name 3dfx Voodoo Series
Total Local Video Memory 32 MB
Total Local Texture Memory 24 MB
Total AGP Memory 0 bytes
Display Driver 3dfx16vs.drv
Display Driver Version 4.12.01.0584
Driver WHQL Certified Yes
Max Texture Width 2048
Max Texture Height 2048
Max User Clipping Planes 0
Max Active Hardware Lights 0
Max Texture Blending Stages 2
Textures In Single Pass 2
Vertex Shader Version N/A
Pixel Shader Version N/A
Max Vertex Blend Matrices 0
Max Texture Coordinates 2
Vendor ID 0x121a
Device ID 0x0009
Sub-System ID 0x0003121a
Revision 0x01
DISPLAY MODES
Resolution 320x200x16-bit RGB [565]
Resolution 320x240x16-bit RGB [565]
Resolution 400x300x16-bit RGB [565]
Resolution 512x384x16-bit RGB [565]
Resolution 640x400x16-bit RGB [565]
Resolution 640x480x16-bit RGB [565]
Resolution 720x480x16-bit RGB [565]
Resolution 720x576x16-bit RGB [565]
Resolution 800x600x16-bit RGB [565]
Resolution 960x720x16-bit RGB [565]
Resolution 1024x768x16-bit RGB [565]
Resolution 320x200x32-bit RGB [888]
Resolution 320x240x32-bit RGB [888]
Resolution 400x300x32-bit RGB [888]
Resolution 512x384x32-bit RGB [888]
Resolution 640x400x32-bit RGB [888]
Resolution 640x480x32-bit RGB [888]
Resolution 720x480x32-bit RGB [888]
Resolution 720x576x32-bit RGB [888]
Resolution 800x600x32-bit RGB [888]
Resolution 960x720x32-bit RGB [888]
Resolution 1024x768x32-bit RGB [888]
TEXTURE FORMATS
Pixel Format 32-bit ARGB [8888]
Pixel Format 16-bit RGB [565]
Pixel Format 16-bit ARGB [1555]
Pixel Format 16-bit ARGB [4444]
Pixel Format 8-bit RGB [332]
Pixel Format 16-bit ARGB [8332]
Pixel Format 8-bit Indexed()
Pixel Format 8-bit YUV [800]
Pixel Format 16-bit AYUV [8800]
Pixel Format 8-bit AYUV [4400]
Pixel Format FourCC [DXT1]
Pixel Format FourCC [DXT2]
Pixel Format FourCC [DXT3]
Pixel Format FourCC [DXT4]
Pixel Format FourCC [DXT5]
3D Capabilities Subpixel Accurate Rasterizing, Stencil Buffers, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.05.01.0900
REGISTERED DIRECTSHOW FILTERS
Filter .RAM file Parser
Filter AC3 Parser Filter
Filter ACELP.net Sipro Lab Audio Decoder
Filter ACM Wrapper
Filter ASF ACM Handler
Filter ASF DIB Handler
Filter ASF DJPEG Handler
Filter ASF ICM Handler
Filter ASF JPEG Handler
Filter ASF URL Handler
Filter ASF embedded stuff Handler
Filter ASX file Parser
Filter ASX v.2 file Parser
Filter AVI Decompressor
Filter AVI Draw
Filter AVI Splitter
Filter AVI/WAV File Source
Filter BDA MPE Filter
Filter BDA MPEG2 Transport Information Filter
Filter BDA Slip De-Framer
Filter ClearVideo® Decompression Filter
Filter Color Space Converter
Filter DV Muxer
Filter DV Splitter
Filter DV Video Decoder
Filter Default DirectSound Device
Filter Default MidiOut Device
Filter File Source (Async.)
Filter File Source (Netshow URL)
Filter File Source (URL)
Filter File stream renderer
Filter IVF source filter
Filter Indeo(R) audio software
Filter Indeo® video 4.3 Decompression Filter
Filter Indeo® video 5.04 Decompression Filter
Filter Internal LMRT Renderer
Filter Internal Script Command Renderer
Filter Line 21 Decoder
Filter Line 21 Decoder 2
Filter Lyric Parser
Filter MIDI Parser
Filter MJPEG Decompressor
Filter MPEG Audio Decoder
Filter MPEG Layer-3 Decoder
Filter MPEG Video Decoder
Filter MPEG-2 Demultiplexer
Filter MPEG-2 Sections and Tables
Filter MPEG-2 Splitter
Filter MPEG-I Stream Splitter
Filter Microsoft MPEG-4 Video Decompressor
Filter Multi-file Parser
Filter NSC file Parser
Filter Overlay Mixer2
Filter QT Decompressor
Filter QuickTime Movie Parser
Filter SAMI (CC) Parser
Filter TrueMotion 2.0 Decompressor
Filter URL StreamRenderer
Filter VBI Surface Allocator
Filter VGA 16 Color Ditherer
Filter VIVO Audio Decoder Filter
Filter VIVO Video Decoder Filter
Filter Video Renderer
Filter Voxware MetaSound Audio Decoder
Filter Voxware MetaVoice Audio Decoder
Filter WM ASF Reader
Filter WM ASF Writer
Filter WST Decoder
Filter Wave Parser
Filter Windows Media Multiplexer
Filter Windows Media source filter
Filter XML Playlist
MEMORY INFO
Total Physical Memory 512 MB
Free Physical Memory 63.53 MB
Total Pagefile Memory 1.50 GB
Free Pagefile Memory 1.46 GB
MEMORY ARRAYS
Max Module Capacity 512 MB
Location System Board
Use Flash
Supported Error D&C None
Supported Speeds <unknown>
Supported Types <unknown>
Supported Voltages <unknown>
MEMORY SLOTS
Installed & Enabled Size 512 MB
Form Factor DIMM
Frequency 0 Hz
Slot BANK_0 [Bank0/1]
Manufacturer
Type <unknown>
Type Details <unknown>
Enabled Size 512 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 0 bytes
Form Factor DIMM
Frequency 0 Hz
Slot BANK_1 [Bank2/3]
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0 Hz
Slot BANK_2 [Bank4/5]
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0 Hz
Slot BANK_3 [Bank6/7]
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer
Model 8363-686A/B
Version N/A
BIOS Vendor Award Software International, Inc.
BIOS Version 6.00 PG
BIOS Release Date 03/26/2001
BIOS Properties Plug and Play, Flash, AGP
CARD SLOTS
Number 0
Designation ISA
Type ISA
Characteristics 5.0V
Data Bus Width 16
Details Long
Device Class <unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID 0x0000
Device ID 0x0000
Device Sub-System ID 0x00000000
Device Revision 0x00
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation ISA
Type ISA
Data Bus Width 16
Details Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 1
Designation PCI
Type PCI
Data Bus Width 32
Details In Use, Long
Device Class Display Adapter
Device Name 3dfx Voodoo Series
Device Manufacturer 3dfx Interactive, Inc.
Device Driver Date 7- 9-2000
Device Vendor ID 0x121a
Device ID 0x0009
Device Sub-System ID 0x0003121a
Device Revision 0x01
IRQ 9
Number 2
Designation PCI
Type PCI
Data Bus Width 32
Details Available, Long
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 3
Designation PCI
Type PCI
Data Bus Width 32
Device Class Network Adapter
Device Name Realtek RTL8139(A/B/C/8130) PCI Fast Ethernet NIC
Device Manufacturer Realtek
Device Driver Date 5-25-2000
Device Vendor ID 0x10ec
Device ID 0x8139
Device Sub-System ID 0x813910ec
Device Revision 0x10
IRQ 10
Number 4
Designation PCI
Type PCI
Data Bus Width 32
Device Class SCSI Controller
Device Name Adaptec AHA-294X/AIC-78XX PCI SCSI Controller
Device Manufacturer Adaptec
Device Driver Date 4-23-1999
Device Vendor ID 0x9004
Device ID 0x7178
Device Revision 0x03
IRQ 11
Number 0
Designation AGP
Type AGP
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
SYSTEM DEVICES
Description VIA Standard CPU to PCI Bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0305
Subsystem ID 0x00000000
Revision 0x03
Description VIA CPU to AGP controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x8305
Revision 0x00
Description VIA Tech VT82C686 PCI to ISA bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x0686
Subsystem ID 0x00001106
Revision 0x40
Description VIA Tech VT82C686 Power Management Controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x3057
Subsystem ID 0x30571106
Revision 0x40
Revision 2.0
Rate 1x
Aperture Size 4 MB
Sideband Addressing supported (disabled)
Fast Write not supported
MONITOR INFO
MONITORS
Name Plug and Play Monitor
Manufacturer (Standard monitor types)
Max Width 1024
Max Height 768
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System Microsoft Windows 98
Version 4.10.2222 A
Service Pack A
Locale US
Desktop Width 800
Desktop Height 600
Desktop BPP 32
HARD DISK INFO
HARD DISKS
Name GENERIC IDE DISK TYPE47
Manufacturer (Standard disk drives)
Capacity 111.76 GB
Model <unknown>
Interface Type <unknown>
Name GENERIC IDE DISK TYPE80
Capacity 76.29 GB
Model <unknown>
Name MATSHITA PD-1 LF-1000
Capacity 13.82 GB
Model <unknown>
    138.27 KiB
    100.48 KiB
Reply 38 of 38, by Vipersan
Well I just had to know ..
The heatsink I ordered for the Radeon9800se arrived ..and was fitted.
Another OS built on a seperate HD (98se)
and the Voodoo5500 replaced with the Radeon9800se (AGP)
So basically the same hardware ..
3Dmark2001 run up and the card tested..
This time (obviously) there were no hardware missing passes ..and the test completed smoothly.
3Dmark was 5350
I guess the choice for gaming is obvious ..though I think the Voodoo would produce wonderful results for period correct games.
I wonder if you can fit both ...🤣..
I'll probably just build another PC for earlier games which uses the Voodoo to its full potential.
It does make you wish 3DFX hadn't been bought out and dumped..
sadly ..that's life..
I have 2 wonderful cards..but each belonged to a time slot now gone.
cest la vie.
