First post, by GabrielKnight123
I have a fan that is dead and on the sticker it has:
DC 12V 0.16A im looking at a Noctua fan redux here:
https://www.scorptec.com.au/product/Cooling/4 … F-R8-REDUX-1800
and under the Noctua's specs page it says "Max input current = 0.11A" will this Noctua be ok to use in an AT power supply as the original fan was getting 0.16 amps and the max for the Noctua is 0.11 amps?
Reply 1 of 2, by Slot1
It should be fine, it uses less power than the original fan therefore the psu can provide it.
Reply 2 of 2, by konc
Completely the other way around of what you think about it. This number is what the fan will actually ask for, not what it can withstand.
