First post, by AllTinker
- Newbie
Hey all, I've been gradually trying to get some of my GOG.com copies of games running on native DOS 6.22 and Win98 SE as appropriate.
There was an old topic, but rather than necro that or make a post just for one game I thought I'd start a new thread to share findings on getting the more stubborn ones working...
Both Unreal Gold and Descent 3 were supplied with the nGlide wrapper, which I removed by deleting the following nine files:
nglide*.* (3 files)3DfxSpl*.dll (3 files)glide.dll, glide2x.dll, glide3x.dll
While Unreal Gold started working fine after this on my Banshee, it seems Descent 3 has been otherwise modified and just crashes back to desktop.
After some trial and error I found that installing the 1.4 no-CD patch over the top did the trick! (Attached below, originally from descent3.com here).
EDIT: It's possible that the 1.5 patch would work as well since it also seems to contain the full executables, rather than just deltas.
I've got a short-list of games to try so if I figure any others out I'll post about them here, or if anyone has figured out fixes for other games I - along with others I'm sure - would be keen to hear about it!
____________________________________________________________________
EDIT 2: Rather than spam the thread I'm going to just edit this post with my findings.
My process for installing these is to install them on my modern PC, then copy the installed files over and perform the given steps.
Apparently you can use innounp to unpack the offline installers manually but I haven't tried it myself yet.
Unreal Gold
- Remove the nGlide wrapper - see above for file list. Optional I guess if you don't have 3DFX hardware, but I can't attest to how the wrapper runs on vintage gear.
Descent 3
- Remove the nGlide wrapper, as with Unreal Gold.
- Install the 1.4 no-CD patch over the top (or quite possibly the 1.5 patch, both available here):
Thief Gold
- Copy the files found in backup\no_ddfix\ to the root directory of the game - replacing THIEF.EXE and CAM.CFG.
Thief 2
- Copy the files found in backup\ to the root directory of the game - replacing THIEF2.EXE and CAM.CFG.
Wing Commander Prophecy
- Install the following registry settings AFTER editing the "Installed To:" line to suit your setup (or change it via regedit later):
Wing Commander IV DVD
- Download this package, or see my post here for the original sources if you prefer.
- Unzip it into your WC4 directory overwriting all files.
- Install AC3Filter via codecs\ac3filter_1_63b_win9x.exe.
- Install the K-Lite MPEG decoder pack via codecs\klmpeg101.exe. On my P2-400 the Cyberlink video decoder had best performance/reliability. Others recommend Ligos, but it ran like garbage for me!
- Run the 'configure dxmci' shortcut and set the path to the vob\ directory. (Otherwise it'll try to read from c:\vob).
