First post, by w0lf42
- Newbie
For complex reasons, I need to make my analog input available for something else. So, I'm attempting to move the signal from my Yamaha MU80 into a different input.
According to the 40-pin header on the sound card, pin #27 is a MIDI Input. So, I (1) made a MIDI to 3.5 mm headphone cable, (2) connected that to a female 3.5 mm headphone jack, and (3) connected the pins on the headphone jack to the correct pins on the sound card header.
I know that the cable works because I am currently using the cable (and female headphone jack) to connect to the MIDI Out on the sound card header. I also know that the 5V and Ground connections on the sound card header are connected correctly, because I'm using those for the same MIDI Out connection.
I have looked at the Volume Play Control (the yellow speaker in the system tray) and I have looked at all of the input/output volumes. I don't see a MIDI In.
I opened up AudioHQ (under Control Panel) and looked at all of the options under Mixer.
I opened up Multimedia (under Control Panel) and looked at all of the options (the MIDI tab is where I tell windows to send my MIDI signal out to my Yamaha MU80). Under the Devices tab there is an item called MIDI Sequencer Device (under Media Control Devices). I haven't adjusted setting there. I don't what things do there.
Under Device Manager, I have no warnings or incorrectly configured hardware.
If anyone has any suggestion, please let me know. Thanks.
Here is the hardware that I believe to be relevant. I can include more if that helps.
Asus CUV4X-E
Creative Labs Sound Blaster Live! 5.1 SB0060
Yamaha MU80
Here is the software that I believe to be relevant. Again, I can include more if that helps.
Windows 98 SE
MS Windows Security Update CD February 2004
DirectX 9.0c
Sound Blaster Drivers from Creative Labs Website - SBL51_W9xME.exe released April 01, 2002
