MDA/CGA/EGA to VGA Converter Released!
Reply 300 of 341, by matze79
Nice Machine 😀
now make a ISA Adapter 😁, it just uses other Type of Slots.
GDR Stuff is really amazing 😁
Reply 301 of 341, by dreamblaster
3d printed enclosure coming soon, as well... stay tuned...
or contact me if you are interested, i will have a few early on,
and more in the webshop later
107.84 KiB
Thanks for your support !
Reply 303 of 341, by dreamblaster
245.02 KiB
378.19 KiB
279.74 KiB
314.15 KiB
early printout, what do you think ?
still some minor changes planned : somewhat larger screw holes in lid (I didnt have/find suitable screws)
Reply 304 of 341, by j^aws
^^ Looks great as it is. The bold colouring - black and red (orange?), is very 80s. The only thing I would change is the size of the font, so that its more discrete. Otherwise, a fantastic job.
Reply 305 of 341, by dreamblaster
thanks, yeah the design is deliberately 'unsubtle' or 'bold', including the font 🤣
yeah on the photo it looks orange, but the actual color is bright 'alarming' red
Reply 306 of 341, by dreamblaster
Okay, I have some enclosures available now, pm if interested 😀
Reply 308 of 341, by dreamblaster
awgamer wrote:
Does it handle composite?
only RGBI input
Reply 309 of 341, by dreamblaster
new, final 3d prints ready !
    286.97 KiB
    343.94 KiB
    306.42 KiB
    176.43 KiB
Reply 310 of 341, by dreamblaster
Youtube review by LGR : https://youtu.be/9SII7ujB3FY
Reply 311 of 341, by dJOS
Good review, what's the latest FW for these?
PS, I really must order your case for mine!
The impossible often has a kind of integrity which the merely improbable lacks.
Reply 312 of 341, by dreamblaster
The latest good working firmware (as seen on LGR) is the one from github, from march 31st : https://github.com/lfantoniosi/mce2vga/tree/m … er/output_files
I am now shipping out all boards with this version.
Earlier prototype PCB's may have had a different firmware (not intentional), and did not do composite mode correctly.
So if you have issues with composite mode, it makes sense to update to exactly this version - see also attachment (jic file from github)
    mce2vga.zip
    84.16 KiB
    120 downloads
Reply 313 of 341, by dJOS
dreamblaster wrote:
The latest good working firmware (as seen on LGR) is the one from github, from march 31st : https://github.com/lfantoniosi/mce2v […]
Cheers, I can't recall what version I put on mine, I'll have to fire up the blaster and update.
Reply 314 of 341, by chrisNova777
great news... i might actually get to use my ATI EGA Wonder card on my AM386DX40 afterall
Reply 315 of 341, by Anonymous Coward
Does this device support multisync EGA modes like 640x480 and 800x600 etc?
Reply 316 of 341, by ibmapc
I can't get mine to work with anything above 640x350 using my ATI EGA wonder. I've been meaning to ask retrocanada76, the designer of this device, if the firmware could be modified to support those higher resolutions.
Reply 318 of 341, by retrocanada76
640x480 and 800x600 are on the VGA spectrum. The device does not have memory enough for holding an entire frame. Unless you design a pass-through mode only converting the TTL to analog. But since I don't have one of these and I don't plan buying one I won't bother.
But there is an easier way to make an adapter for these modes, the VGA is 0.7Vpp so if this output is 6 bit like R1R0G1G0B1B0 all you do is to provide each line a 2 resistor in parallel:
R0 : 1500 ohm
R1 : 750 ohm
G0 : 1500 ohm
G1: 750 ohm
B0: 1500 ohm
B1: 750 ohm
The VGA has a 75 ohm impedance: 5V * (75 / (1500 + 75) + 5V * (75 / (750 + 75)) will give you 0.6926Vpp
The H and V sync are TTL on VGA so just connect them direct. This should work beautifully...
Reply 319 of 341, by ibmapc
@retrocanada76 I made this sketch to see if I understand what you said. Is this right?
61.73 KiB
Of course I'd connect the Hsync, Vsync, and GND.
