DOSBox ECE (for Windows & Linux)
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: DOSBox ECE (for Windows)
Postby Qbix » 2018-8-24 @ 16:53
you have to go back quite a while. 4074. I hope it gets commited soon (by the mame people)
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Stiletto » 2018-8-24 @ 18:46
Qbix wrote:you have to go back quite a while. 4074. I hope it gets commited soon (by the mame people)
Pull Request #? Maybe I can prod some people.
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby Qbix » 2018-8-27 @ 11:17
The tandy sound changes are commited. It solves sentinel title music and the kq2 title song and the waves.
User avatar
Qbix
DOSBox Author
Postby Yesterplay80 » 2018-8-27 @ 11:18
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby JemyM » 2018-8-27 @ 16:51
Never mind, I figured it out. (I actually didn't but then Qbix came in to save the day)
Okay, now roll sanity.
User avatar
JemyM
Postby Qbix » 2018-8-27 @ 17:07
DOSBox -c "Mount C 'C:\My Favorite DOS Games\Personal Nightmare'" -c "c:" -c "cd pnite" -c "test"
User avatar
Qbix
DOSBox Author
Postby JemyM » 2018-8-27 @ 17:24
Qbix wrote:DOSBox -c "Mount C 'C:\My Favorite DOS Games\Personal Nightmare'" -c "c:" -c "cd pnite" -c "test"
Awesome! Now I am up and running again. Thank you :)
User avatar
JemyM
Postby lukeman3000 » 2018-8-28 @ 21:19
Yesterplay80 wrote:And a new ECE is ready to download: https://dosbox.yesterplay80.net/DOSBox%20ECE%20r4141.7z
Awesome, thanks!
I have another question - I'm not sure if this is something that's more suited for the ECE thread or otherwise, so let me know if this isn't the right place to ask.
I'm using D-Fend Reloaded, and it has an option to center the dosbox window. However, for whatever reason, the dosbox game window ends up not being centered after the resolution adjusts.
I am able to add an environment variable to center SDL windows (and this fixes the problem), but I was wondering if there might be some way to correct for this in a future ECE release without having to set an environment variable?
lukeman3000
Postby Ant_222 » 2018-8-31 @ 22:42
lukeman3000 wrote:I am able to add an environment variable to center SDL windows (and this fixes the problem), but I was wondering if there might be some way to correct for this in a future ECE release without having to set an environment variable?
I have gone so far as to request that MinGW add support for a function that would let me center the window programmatically, and the maintainer fulfilled it, yet it might still be unavailable in the Visual Studio run-time.
Other than that, SDL2 supports the centering of its windows.
Ant_222
Postby collector » 2018-9-19 @ 04:59
I am not seeing a plain vanilla build on your page. Are you no longer offering one or am I just missing it?
User avatar
collector
Postby Dagar » 2018-9-19 @ 13:38
collector wrote:I am not seeing a plain vanilla build on your page. Are you no longer offering one or am I just missing it?
It shows for me on his website and Google Drive:
DOSBox r4162.7z
Dagar
Postby Yesterplay80 » 2018-9-20 @ 15:00
You seem to be missing it, as Dagar said, it's on the website and my Google Drive. Or maybe you were looking for it the exact same second I moved the old ones into the archive folder before uplaoding the new ones. :)
User avatar
Yesterplay80
Postby collector » 2018-9-21 @ 07:13
That must be the case. I see them now.
User avatar
collector
Postby inukaze » 2018-9-23 @ 18:11
Linux Version, i can't compile, hi there Yesterplay80.
today i had download DOSBox ECE r4162 (Linux).7z
but i can't compile because i not have a file. there is the output :
Code: Select all
    Makefile:369: recipe for target 'midi_mt32.o' failed
    make[3]: *** [midi_mt32.o] Error 1
    make[3]: *** Se espera a que terminen otras tareas....
    Makefile:369: recipe for target 'midi.o' failed
    make[3]: *** [midi.o] Error 1
    mv -f .deps/pixelscale.Tpo .deps/pixelscale.Po
    mv -f .deps/render.Tpo .deps/render.Po
    mv -f .deps/sdlmain.Tpo .deps/sdlmain.Po
    mv -f .deps/sdl_mapper.Tpo .deps/sdl_mapper.Po
    mv -f .deps/render_scalers.Tpo .deps/render_scalers.Po
    make[3]: Leaving directory '/media/Compartido/Liñux/cdf/dosbox-ece/src/gui'
    Makefile:444: recipe for target 'all-recursive' failed
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory '/media/Compartido/Liñux/cdf/dosbox-ece/src'
    Makefile:376: recipe for target 'all-recursive' failed
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory '/media/Compartido/Liñux/cdf/dosbox-ece'
    Makefile:317: recipe for target 'all' failed
    make: *** [all] Error 2
i dont know from where i should got that file, and where i must put, to compile this version on :
Devuan (Jessie), Slackware (14.2), Gentoo, ArtixLinux, GoboLinux, Sorcerer Linux.
inukaze
Postby gdjacobs » 2018-9-23 @ 21:59
What platform are you using?
User avatar
gdjacobs
Postby inukaze » 2018-9-24 @ 22:47
Platform : PC
Operating System : GNU/Linux
i had solved with the follow commands on cli :
Code: Select all
git clone https://github.com/munt/munt
cd munt
mkdir build ; cd build
cmake -DCMAKE_INSTALL_PREFIX=/usr ..
make -j
su -c "make install" root
i put on my spanish dosbox tutorial [Work in Progress] -> https://docs.google.com/document/d/1CGA ... sp=sharing
Well i need to know
1) i need 3dfx drivers for msdos games with dosbox-ece ?
2) where i can find a list of games for msdos and/or window9x with 3dfx support ?
inukaze
Postby Yesterplay80 » 2018-9-25 @ 06:44
inukaze wrote:Well i need to know
1) That depends on the game, but most games should come with the needed driver included. You don't need any additional driver or mapper.
2: viewtopic.php?t=14486
User avatar
Yesterplay80
Postby inukaze » 2018-9-26 @ 10:38
Thank you very much for your answers. right now i had tested Tomb Raider 3DFX Demos, and works perfectly :D
Well on the weekend i try to install and confgiure Windows9x
inukaze
Postby inukaze » 2018-9-27 @ 01:05
For Windows95 (RTM) and (B) and Windows98SE, which drivers i need for Video and Voodoo ?
inukaze
Postby Yesterplay80 » 2018-10-02 @ 11:16
inukaze wrote:For Windows95 (RTM) and (B) and Windows98SE, which drivers i need for Video and Voodoo ?
Drivers for a S3 Trio and a Voodoo 1 might work.
FYI: I included two new pacthes into DOSBox ECE, now allowing for mapping mouse buttons to keyboard or controller buttons and for separate sensitivity settings for the X and Y axis of the mouse. Settin the Y axis to 0 results in a disabled Y axis, basically which had to be done with the TSR tool novert.com before.
User avatar
Yesterplay80
PreviousNext
Return to DOSBox Development
Who is online
Users browsing this forum: Bing [Bot], knowledge [bot] and 0 guests
