Reply 9640 of 27506, by ultra_code
Finally tested out my dirty AWE64 Gold that I received a while back in my Pentium machine (even after three isopropyl alcohol spray-downs and some lovin' with Q-tips and compressed air, it still isn't 100% clean; oh well). Thankfully, it works.
However, the Cirrus Logic PCI graphics card started acting up today as well, as shown in the picture below:
I tried cleaning the card's contacts with some isopropyl-alcohol-tipped Q-tips and re-seating the card, to no avail. Is the poor thing truly dying, and if so, is there anything I could do? 🙁
Builds
Reply 9641 of 27506, by appiah4
Flashed a second GOTEK to the FlashFloppy firmware. Now I have 1 HxC and 2 Flashfloppy GOTEKS. The HxC is serving as a df1: external floppy drive for my A500/ACA500+, the FF ones are in my Roland SD-35 and 486 PC. Life is gud. 😎
Reply 9642 of 27506, by stamasd
Just curious, which method did you use for the flashing? I recently flashed 2 of these as well. I tried the USB method with the A-to-A cable but it didn't work. The ST software would not recognize either of the 2 Goteks as a valid target. I had to go with the USB-serial method, and even that one was difficult; I had to apply pressure on the PCB in a certain point for the method to work, I think the quality of recent Goteks has gone down and the PCBs have some hardware issues.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 9643 of 27506, by appiah4
I soldered on the missing headers and used a USB-TTL adapter. the USB A-A cable thing did not work for me either, but I guess it was due to cheap chinese cables.
Reply 9644 of 27506, by stamasd
Hm. It's probably not the cable as I used a good quality A-A cable. Interesting. So the serial method is the only one that works in recent Goteks.
I/O, I/O,
I/O, I/O
Reply 9645 of 27506, by appiah4
I wouldn't know if that is certainly true but I couldn't get it recognized with my PC; it may have to do with USB drivers etc. as well..
Reply 9646 of 27506, by Duouk2000
Got hold a cheap LCD monitor, Amstrad PC works fine with it, the Dell and Tiny PCs give no image. I also remembered my current gen PC actually has a built in VGA port so I tried that with my Trinitron and again everything worked fine. So at least the CRT is OK, it just means I have two duff PCs. If nothing else I can harvest them for parts while I wait for my Abit KT7 to arrive.
The LCD is 1024x768 and give a surprisingly nice image at that resolution. I'm quite impressed.
I've also been trying my hand at mapping with Akalabeth. Not made my way past level 4 of a dungeon yet and quickly realised I'd be better of with a pencil rather than a pen; so far it's been good fun (when I'm not falling through multiple trap doors to my doom that is 😵).
Reply 9647 of 27506, by McBierle
Putting together a Pentium 90. Just now playing with the LCD-Display.
526.47 KiB
While i'm waiting for a Slot-A heatsink for this newly bought board+cpu:
812 KiB
Reply 9648 of 27506, by Cyrix200+
McBierle wrote:
<snip>
Did you also get the GFD?
1982 to 2001
Reply 9649 of 27506, by luckybob
Cyrix200+ wrote:
McBierle wrote:
<snip>
great minds think alike, eh?
Reply 9650 of 27506, by appiah4
Where did you get one? I have an Athlon 700 that needs a Slot-A heatsink..
Reply 9651 of 27506, by Cyrix200+
You should be able to also use a SECC1 Pentium 2 heatsink, if I'm not mistaken. Not that those are any easier to find but it might give you some more search options.
1982 to 2001
Reply 9652 of 27506, by luckybob
+1
I personally use these: https://www.ebay.com/itm/Intel-SL2U3-Pentium- … fYAAOSw-ZBZpywP except a briglt BLUE.
You will need a hex-bit to get them off BTW.
Reply 9653 of 27506, by wiretap
Installed a new facia into the Voodoo 5 Shuttle. The cool thing is now that I designed a template, I can make it whatever design/art/color I want. 😁
My Github
Circuit Board Repair Manuals
Reply 9656 of 27506, by bjwil1991
Tested the C64 by hooking it up to my 43" UHD TV (aspect set to 4:3) to make sure it still works and it does.
Reply 9657 of 27506, by xjas
wiretap wrote:
Installed a new facia into the Voodoo 5 Shuttle. The cool thing is now that I designed a template, I can make it whatever design […]
Yikes. Knowing how hot mine gets with just the onboard video I'm guessing you do not want to close that case. Neat system though (& nice job with the front panel!)
Reply 9658 of 27506, by Merovign
I'm guessing VRAM, though it could be software. I mean, if you can test it in another machine, that would be a good idea. If it turns out to be the VRAM, it's probably cheaper to replace the card rather than fix it, which is sad.
It is *possible* to fix anything. If I found another identical card, I'd keep the old one for spare parts.
*Too* *many* *things*!
Reply 9659 of 27506, by wiretap
It's not bad. Gaming for an hour on Quake 3, it stays around 58C with the case closed.
My Github
