First post, by aries-mu
Curiosity:
Do you think that a dedicated-PSU-powered GeForce GTX 1080Ti via PCI Express-to-AGP to AGP-to-PCI to PCI-to-ISA set of adapters would work in an MS-DOS and Windows 3.0 based 20 Mhz 286, with the support of a skilled programmer that will write drivers accordingly?
Is the human being able to do this already born?
Thanks
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
Reply 1 of 12, by BinaryDemon
That's pretty ridiculous, unless Nvidia wanted to do this I can't see it working.
But, I bet you could come close to simulating 286 performance by taking a semi-modernish CPU/mobo that does support PCI-e reducing it to slowest clock speeds and disabling all cache. You could even use a PCI-e 16x to 1x adapter and possibly throttle the PCI-e speed in BIOS (if supported).
Personally I'd use a modern OS on it, because what kind of meaningful benchmark are you going to run under Windows 3.0?
Reply 2 of 12, by derSammler
No. Apart from the fact that you can't adapt PCIe to ISA, a 286 would not even be able to execute (or even address) the BIOS of the card.
Reply 3 of 12, by Standard Def Steve
agent_x007 paired a GTX 1080Ti with a Northwood Celeron, courtesy of a rare S478 PCIe motherboard. Those Northwood-128 chips aren't much faster than a 286. 😁
"A little sign-in here, a touch of WiFi there..."
Reply 4 of 12, by mrau
will nvidia's driver even fit in the 16mb max of ram that can be addressed?
edit: its not even 16 megs - devices have to fit in that space too :>
Reply 5 of 12, by oeuvre
pff, RTX2080 is what you want to pair with a 286
Reply 6 of 12, by The Serpent Rider
Good luck reverse engineering proprietary Nvidia spaghetti code drivers to fit them into 16-bit system. Heck, at least AMD has open source drivers for old GPUs.
Reply 7 of 12, by aries-mu
No fun in simulating. The real thing would be the real fun! The tougher the challenge, the greater the fun!
Again, the tougher the challenge… (same as above ↑). A work worth thousands of resumes in IT!
🤣! Respect bro!
You totally have a point! Mmmm…..
Ahahahahahaha FANTASTIC! I was undecided about mentioning that… I just wanted the thread popularity to spike… but, definitely! Yes, let’s change plan, let’s go with the RTX2080 in the 286!
Hey, why not, a tweaked mobo to get a dual CPU 286? HAHA!
Didn’t think about legality issues… well, whoever will do it will add some hacking/cracking to the resume! (y)
Reply 8 of 12, by gdjacobs
I think you would sooner be capable of making a 286 in a Geforce GTX 1080Ti.
Reply 9 of 12, by luckybob
Can I buy drugs from you?
Reply 10 of 12, by cyclone3d
You don't need a PCIe to AGP and AGP to PCI adapter to go from PCIe to PCI.
You just need a PCIe to PCI adapter with auxiliary power or a PCIe extension cable or riser with a power plug if you want to use a video card.
And yeah.. no way to do adapt a PCI card to run on ISA that I kknow of. You can do the other way though.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 11 of 12, by agent_x007
To be fair : It was a regular GTX 1080, not the Ti : LINK 😉
Reply 12 of 12, by aries-mu
Still!
