Reply 20 of 35, by appiah4
- l33t++
wrote:Why is the Yamaha OPL3 a thing and why should I give more than a Plank length about it?
You shouldn't. CQM is good enough. It's just sounds different in some cases, but not bad as some people may claim.
It's subjective. I feel CQM sounds just fine, but it is definitely not as good as OPL3. But then, OPL3 is not OPL3, it can vary wildly from card to card depending on what clockspeed it is run at and what kind of filtering it uses. For example, PAS OPL3 is vastly different from SB16 OPL3.
Personally, I find properly filtered ESFM to be the most pleasant among FM implementations that obviously try to mimic OPL3. As for variant OPL3s, I think Crystal's FM sounds very, very nice.
I have a pet project whereby I do an in depth comparison/analysis of OPl3/ESFM/Crystal/Aztech/FM801/Aureal synthesis for classic FM soundtracks like Dune and Dune2.. I will do this, some day.
As for the OP's question, AWE64 is a great card, I use it for 96-98 era Win9x builds as its MIDI capabilities are best suited for this OS. I think the CQM vs OPL3 thing is overblown, and the low noise level makes it a great choice for this period. Serdaco (http://www.serdashop.com) still make and sell SIMMCONN adapters for SIMM upgrade modules to this card, though pairing it with an SB Live! and routing its LO to Live!'s LI is usually a cheaper option.
I also have an AWE32 (OPL3 version) that I use or 93-95 era DOS builds. Its MT32 emulation and wavetable header make it a much more valuable card for such builds to me.
