First post, by Windows9566
I try to launch Aces of the Pacific or Aces over europe in DOS 6.22 on either PCem and my DOS machine and i get an error saying
There is not enough memory for 'Aces over Europe' to run.
Your computer may be running a 'pop up' (TSR) program
or it may be connected to a device such as a LAN that
uses a portion of the memory. See the Trouble Shooting
section of the 'Aces over Europe Quick Reference Card' for help.
PCem specs
Award 430VX PCI
Intel Pentium 90
64mb ram
Phoenix S3 Trio64
SoundBlaster 16
DOS 6.22
Real Hardware specs
Intel Anchorage AN430TX
Intel Pentium 133
64mb ram
S3 Trio 64v+
SoundBlaster 16
DOS 6.22
AUTOEXEC.BAT
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 T6
SET MIDI=SYNTH=1 MAP:E
LH C:\SB16\DIAGNOSE /S
LH C:\SB16\MIXERSET /P /Q
LH C:\DOS\SMARTDRV.EXE /X
LH C:\WINDOWS\MSCDEX.EXE /S /E /D:OPTICAL
LH C:\DRIVER\CTMOUSE.EXE /R2
@ECHO OFF
PROMPT $p$g
PATH C:\WINDOWS;C:\DOS
SET TEMP=C:\DOS
CONFIG.SYS
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM
DOS=HIGH,UMB
FILES=60
BUFFERS=11
STACKS=9,256
DEVICEHIGH=C:\DRIVER\VIDECDD.SYS /D:OPTICAL
DEVICE=C:\WINDOWS\IFSHLP.SYS
DOS is a chore to get running right
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 2 of 4, by leileilol
Works in PCem. This is not a bug; welcome to the true DOS gaming experience! We used to make bootdisks to get around this crap!
At least rem out IFSHLP, SETVER and probably your cd-rom driver in config.sys. Since you have DOS 6.22 you could probably try MEMMAKER for luck as well.
Debian's fucked
Reply 3 of 4, by Windows9566
I disabled SMARTDRV in autoexec and it finally launched
IBM Thinkpad 760LD
