Reply 25300 of 52792, by PcBytes
- Oldbie
wrote:>> >> Beware, there are variations. This below is a layout I found on VX and 486 boards. Connecting the wrong wires may or will […]
wrote:As for the mouse header - it has 5 pins,if that helps. I guess the 2nd pin going from left (my board does have it in place) is NC? It is actually in the same orientation as your picture and it goes up to the 5th pin.
Beware, there are variations. This below is a layout I found on VX and 486 boards. Connecting the wrong wires may or will produce smoke.
I'll check. Visual inspection wise I noticed pin 1 goes to something that looks like either a ceramic cap or a ferrite bead.
Probably the best way is using a DMM and check pin 1 and then pin 5.
Speed wise, cache limit impact isn't that hard, as long as you have all drivers installed. I tested this with a 3.2GB Maxtor installing Windows 98 from HDD. It was pretty slow and I might attribute that mainly because it ran in the uncahched limit.
Gotta live with it though as the only 64MB stick I have is PC133, lmao.
I have also figured the fan pin headers. It's a kind of reversed 3pin header - normal fan are wired blk/red/yellow - this was not the case here. This board has it wired this way - red/blk/yellow. Took me a while to find out.
Another thing I was surprised to find is an ATX header, and right next to it, a DIP slot (much smaller than a BIOS chip) that is unused.
