Best cpu for Voodoo Banshee
First post, by MKT_Gundam
What the best cpu for Voodoo Banshee ?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 1 of 26, by leileilol
The same best CPU for the Voodoo3.
FUCK "AI"
Reply 2 of 26, by Zup
I had both cards installed in a Pentium II@333 (overclocked to 350). I guess that Pentium II and earlier Pentium III would be correct for that card, but maybe not the best CPUs.
Also I put my Voodoo 3 in my Athlon@1Ghz but by that time games (i.e.: GTA3) were increasingly incompatible with Voodoo cards so, although the CPU may be fine, I don't think it would be a good choice at that time.
I'm selling some stuff!
Reply 3 of 26, by derSammler
I'd say a PIII between 800 - 1000 MHz would do best for that card.
Reply 4 of 26, by mwdmeyer
I agree with Zup. Pentium 2, Early Pentium 3. I think late model P3 is overkill.
Reply 5 of 26, by MKT_Gundam
The Banshee dont scale well like the V3?
Reply 6 of 26, by nforce4max
I don't think that this card needs a lot just to get by even though it always helps but you can always use the card in slower systems just fine if you don't mind the reduced performance. This era of hardware is only getting more expensive thanks to people on youtube and eBay profiteers jacking the prices so when the preferred options becomes too expensive it is ok to settle for something else.
P2 and early P3 are just fine in my opinion along with similar performing K6, good card for dos in a pinch having a great 2D core.
Reply 7 of 26, by Putas
How could it?
Reply 8 of 26, by TimWolf
Greetings, trying to ascertain whether or not a 16 megabyte Banshee Voodoo 2 would be a good fit for a Pentium one MMX 266, possibly over clock to 300 megahertz. I don't really want to put it in a Pentium II since my BX chipset motherboard can go all the way up to Tualatin. I realize this is a necrobump, but it seems this question of mine has already been talked about here, somewhat.
Thanks in advance ,
TW
Reply 9 of 26, by mwdmeyer
I've got a Voodoo 2 in my 200MMX and it works well, so a Banshee should be fine/good fit.
Reply 10 of 26, by pc-sound-legacy
Banshee was the entry level 3DFX card. So it will perfectly fit with a Slot1 Celeron 300A of the same era. Great combo for a Windows 98 system.
Reply 11 of 26, by MKT_Gundam
HI guys!
Already using the banshee on my VIA C3 rig.
Good combo.
Reply 12 of 26, by foil_fresh
i was running a banshee with a k6-2+ 550 for a while and it seemed like a good pairing.
Reply 13 of 26, by candle_86
I'm using a v3 on a k6-3+ so a banshee should be fine
Reply 14 of 26, by kolderman
C3/K6+. You are in the era where a CPU that can be slowed down is desirable, as the Banshee is also an excellent 2D card for DOS games.
Reply 15 of 26, by candle_86
kolderman wrote on 2021-01-29, 18:44:
Don't forget 3DFX having the best 3d now support in their drivers
Reply 16 of 26, by rain
Pentium 2 with banshee very slow with carmageddon2 .
pentium 3 better
but pentium 4 best
Reply 17 of 26, by ratfink
Yay necro post. My Banshee runs great with a 700mhz Athlon.
Reply 18 of 26, by stamasd
My Banshee runs... well not at all because I can't remember in which storage box I put it. 😜 But when I was testing it, it was with a P2-400 and I was not impressed.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 19 of 26, by soggi
rain wrote on 2024-09-28, 17:35:
pentium 3 better
but pentium 4 best
But not AGP Banshee, as most P4 boards will fry the card (and maybe some other parts) in the worst case.
and sorry for adding another post to (useless) necro posts.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
