First post, by olddos25
Well, I encountered this bug recently. In Lemmings and Oh No! More Lemmings (using the CD version BTW) when you finish a level, you have the option to continue to the next level or to return to the title screen. If I choose to be taken to the title screen, I go to it, and then the game hangs.
If I choose to continue to the next level, it still takes me back to the title screen to then hang! Newer versions are supposed to solve problems, not originate new ones! Because I then tried with the 0.74-2 release and that doesn't happen. Can it get fixed? Thanks beforehand!
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Emaculation: https://www.emaculation.com/forum (as macplus)
Reply 1 of 11, by dr_st
I think if you click the mouse again or press Esc or some other key on the keyboard it might unfreeze.
Reply 2 of 11, by olddos25
Tried those things to no avail. It just doesn't respond to anything, neither keyboard buttons or mouse buttons.
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
do you use the same sdl.dll with both versions ?
Some SDL.dll versions generate extra mouse button press events, which lemmings doesn't like.
Not sure if this is the case for your problem though
Water flows down the stream
Reply 4 of 11, by olddos25
Nope. Neither with DOSBox 0.74-2 or DOSBox SVN. The thing is, I originally discovered this problem in DOSBox ECE. And I said to myself, "maybe the patches are causing problems". And the rest is history.
Reply 5 of 11, by olddos25
Update: I recently discovered that when I press the right mouse button with the title screen locked up, it unfreezes for some reason. And then I can continue to the next level like normal. That's neat, but a little strange...
Reply 6 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
but which sdl.dll are you using with the SVN ?
Reply 7 of 11, by olddos25
With DOSBox SVN and ECE I am using version 1.2.15.0. i don't know what else you want me to specify tho.
Reply 8 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
and how does it behave if you use the sdl.dll from 0.74-2 with it ?
Reply 9 of 11, by Yesterplay80
I just downloaded the game (for testing purposes only!) but couldn't confirm your problem, even with the SDL.dll coming with ECE. Would you please post your .conf file, maybe it has another reason? Do you run DOSBox under Windows or Linux?
Btw.: What makes you think the game has frozen? Because you can't see a mouse arrow? Are the Lemmings at the bottom moving? Can you choose the options with the F-keys?
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 10 of 11, by olddos25
Qbix, I will test that once I get home.
Yesterplay, I am on Windows and I don't think the conf file is the problem. I'll post a screenshot when I get home.
Reply 11 of 11, by olddos25
Qbix, if I use the SDL from DOSBox 0.74-2 on SVN, it lets me continue. Like, it doesn't go to the title screen to then "freeze" but it goes to the summary screen of the next level.
Yesterplay, it looks more or less like this:
The attachment Captura2.PNG is no longer available
The Lemmings at the bottom of the screen don't move, there normally isn't an arrow on the screen, so I can't see it, and I can't trigger things with the function keys. So yeah, it is frozen.
