micro$oft vbdos
First post, by noshutdown
does it support compiling protected mode exes like watcom and djgpp did? or are there any other basic compilers for dos that do?
Reply 1 of 3, by root42
I think the Microsoft DOS BASIC variants were always real mode and limited to 640K. VisualBasic for DOS was also more related to QuickBasic iirc.
Turbo and Power Basic were also real mode only.
I think protected mode programming for DOS was more or less limited to Assembler, C and C++.
YouTube and Bonus
Reply 2 of 3, by Falcosoft
Not entirely true, even the old Turbo/Borland Pascal 7 compiler supported 286+ 16-bit protected mode DOS target.
Also Free Pascal compiler has 386+ 32-bit protected mode support for DOS for more than 2 decades.
But to answer op's question Power Basic DOS compiler also seems to have/had support for 32-bit protected mode.
(It seems there is a problem with power basic home page, only the forum links are working currently)
https://forum.powerbasic.com/forum/user-to-us … erbasic-for-dos
https://www.powerbasic.com/pbdos.php
@Edit: Sorry, false information. PowerBasic does not seem to support 32-bit protected mode under DOS by default, root32 was right.
But you can download different packages that enable protected mode programming with PowerBasic. E.g:
ftp://ftp.pbhq.de/pbsource/dpmipb.zip
Website, Youtube
VST Midi Driver Midi Mapper
Reply 3 of 3, by Azarien
Borland Pascal 7 did, Turbo Pascal 7 did not - this is the main difference between those two packages.
WATCOM also supports Fortran77, and DJGPP has GNAT (Ada language).
