Reply 25980 of 58405, by bjwil1991
Fancy.
Reply 25982 of 58405, by OldCat
mcobit wrote:
Got this nice TA 80186 machine.
Ah, I see you are a man of culture as well.
Greetings from fellow Hercules fan. Love that amber!
Reply 25983 of 58405, by Thallanor
Yesss!
I got Hexen in the mail, from a VCFED member. To save on shipping, it was packaged inside something else I bought.
This might stir up some controversy, 🤣. I honestly had decent luck with WinMe back in the day, though I found it all came down to what hardware you were running it on. Something <2 years old? Great. Anything else? Hold on tight.
The attachment DSC_0366.JPG is no longer available
Still, I'm pretty tickled to have this. 😁
Reply 25984 of 58405, by liqmat
Thallanor wrote:
Yesss! […]
Yesss!
Yes, I had the same experience with Vista. Why everyone else was having issues with it and hating on it I had zero problems and it was quite a nice OS for me.
Reply 25985 of 58405, by Murugan
Never had Win ME but recently I installed it on my K6-3 build and a Pentium 3 laptop 😀
Haven't tried it in depth so far. I just disabled system restore.
@dionb: sorry for disappointing you with the case 😵 . Gave it a good scrub yesterday. I need to find a way for cleaning the plastic top. I used a chemical on it and it interacted with the plastic 🙁 It was in dirty shape to begin with.
The caps look good but they look the same as on another MSI P3 board. There were 4 or 5 bloated.....Bad quality...
When it's assembled and cleaned again, I'll take care of the BIOS. It does give config errors.
The only thing so far I don't like about this board is the location of the V3 chip and fan. Installing another fan or heatsink interferes with the fan of the CPU.
Reply 25986 of 58405, by appiah4
Not sure why you would install Me if you would disable the only thing that makes it worth your while..
Reply 25988 of 58405, by Murugan
I read about disabling the system Restore on Vogons so I did 😀
Haven't installed the unofficial SP yet.
Reply 25989 of 58405, by root42
Two tubes with some SAA1099P arrived. Were earlier than expected. China mail seems to step up its pace before christmas. 😉
The attachment A5944274-DE74-4BE5-8C3C-764DD000F180.jpeg is no longer available
YouTube and Bonus
Reply 25990 of 58405, by dionb
Been down the same path, this is what mine looked like before cleaning:
After also trying ever more potent chemicals and eventually starting to melt away the paint on one of the side panels, I gave up and threw it in the dishwasher. First run removed all the stains, the second got rid of all the smell. Can recommend - the plastic on your Spheris II should be the same as on my Squarius II.
What irritates me is the lack of mounting holes around the V3 - so you can only cool it with what will stick to it. Big passive heatsinks aren't an option.
Reply 25991 of 58405, by brostenen
Thallanor wrote:
Yesss!
I had nothing but trouble on all my personal hardware, back around 1999/2000 or when that was released.
Yet my parents had an Compaq with an 900 or mhz P3, and Gefore2-GTS. They had zero issues.
Everyone else I knew had all sorts of problems with ME as well.
Indeed you had to have the correct hardware, the correct drivers, and don't you dare change any of that.
If you upgraded the drivers or changed the hardware configuration, you would get into trouble.
Reply 25992 of 58405, by cyclone3d
liqmat wrote:
Thallanor wrote:
Yesss! […]
Yesss!
Vista was absolutely horrible before SP1. After SP1 it was just fine.
The biggest problem I had before SP1 was the massive obvious bug with file transfers. Oh yeah, I want to let my computer take an infinite amount of time to move a folder with files from one drive to another.
Another problem was that the hardware mfgs didn't have any drivers and most of the ones that did had super buggy drivers.
The biggest problem with Vista overall was that the OEMs took Microsoft's minimum system requirements for it and then sold machines with Vista on them that had specs not even good enough to run XP well.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 25993 of 58405, by cyclone3d
"System Restore", even up to Windows 8.1 is nothing more than "maybe get your computer working well enough to recover files".
Past that it is a pile of steaming poo. Nothing ever works right again and it makes everything super flaky.
I also don't have it enabled with Windows 10. Just keep my files backed up. So much easier to just re-install Windows than to use System Restore.
If your computer gets to the point of needing a "System Restore" it is high time Windows is re-installed from scratch anyway.
YMF7x4 Guide
Reply 25994 of 58405, by SSTV2
Just got this AMD slot A motherboard/cpu combo, it's equipped with AMD Irongate chipset.
DFI-AK70:
Worst CPU VRM layout in terms of space-saving I've ever seen, bulgy caps also:
Reply 25995 of 58405, by Thallanor
I am undecided if I will install WinMe on any of my builds yet, not for dislike but because most are MS-DOS builds. But if I do, I too will be looking into the unofficial Service Packs. Heck, same thing if I go with Win95 or Win98SE. 😀
Reply 25996 of 58405, by Thallanor
I suspect, fearing being swamped with support requests, most OEMs stuck very close to a very specific set of hardware with better driver support. That's all I've got. 😁
Reply 25997 of 58405, by Thallanor
Exactly. And I got into Vista so late in the game that it wasn't an issue for me. 😀
Good old "Vista Capable." I remember that. It wasn't new to Vista either, but it certainly had the biggest impact.
Reply 25998 of 58405, by Intel486dx33
PCChips motherboard with AMD Athlon and Via chipset. For a modern computer build to clock down and play 386 computer games.
Reply 25999 of 58405, by sf78
I (almost) hit a jackpot today, I believe it's an 5950 Ultra and it cost me 5€. However, the last mosfet on the right side of the cooler is burned and I need to replace it before I can say if this thing actually works or not. Fingers crossed... 😊
The attachment fx.jpg is no longer available
