MT-32/CM-32L ROM Versions
General information and assistance with Munt.
Postby OmerMor » 2012-2-15 @ 20:56
I want to start a public repository for dumps of all known MT-32/CM-32L ROM revisions.
Currently I host my limited collection via Google Docs, here: https://docs.google.com/open?id=0B5j-_ZMS8_UoY2MxOWRmMzktZmZhOS00M2EwLWFkZGItODNmODY4ZjU5Y2Vi
A list of known ROM revisions can be found here:
http://en.wikipedia.org/wiki/User:Lord_Nightmare
I'd appreciate any help in obtaining more dumps.
Thanks!
OmerMor
Re: MT-32/CM-32L ROM Versions
Postby Dominus » 2012-2-15 @ 21:35
You can't do that here. And you probably know why
User avatar
Dominus
DOSBox Moderator
Postby ElectricMonk » 2014-7-05 @ 17:05
Dominus wrote:You can't do that here. And you probably know why
Theortically, supposing I was able to get the MT-32 and CM-32L LA-Patch ROMs and Control ROMs. What would it entail to get those to work within DosBox and/or ScummVM?
ElectricMonk
Postby Solarstorm » 2014-7-05 @ 19:35
Install MUNT.
User avatar
Solarstorm
Postby ElectricMonk » 2014-7-05 @ 20:17
Solarstorm wrote:Install MUNT.
Munt got absorbed by the ScummVM orject. I was wondering if I could use a virtual synth driver, like BASS, Fluid Synth, or SGM instead of Microsoft GS wavetable eey
ElectricMonk
Postby collector » 2014-7-05 @ 20:33
ScummVM has added Munt into their project, but Munt is still an active stand alone project. Often, the Munt in ScummVM is outdated as Munt's development continues. The ROMs will do nothing for other synths, they are for Roland music only. If you want MT-32 music in DOSBox, you need a special build of DOSBox with Munt incorporated into it, the Munt QT app or, on Windows, the Munt driver. All of these solutions, including ScummVM, require the ROMs.
User avatar
collector
Postby ElectricMonk » 2014-7-05 @ 20:49
collector wrote:ScummVM has added Munt into their project, but Munt is still an active stand alone project. Often, the Munt in ScummVM is outdated as Munt's development continues. The ROMs will do nothing for other synths, they are for Roland music only. If you want MT-32 music in DOSBox, you need a special build of DOSBox with Munt incorporated into it, the Munt QT app or, on Windows, the Munt driver. All of these solutions, including ScummVM, require the ROMs.
What about CM-32L music? There are a few old Lucasrts and Sierra Online games that use that one (since the SCI0 days, anyway)
ElectricMonk
Postby collector » 2014-7-05 @ 22:25
Still doesn't have anything to do with BASS, Fluid Synth or Microsoft GS.
User avatar
collector
Postby realnc » 2018-11-08 @ 22:13
It's been years, but if you're still looking for this stuff, someone is trying to assemble firmware dumps from all old synths, not just MT-32:
http://dbwbp.com/index.php/9-misc/37-synth-eprom-dumps
It has various versions of the MT-32 ROMs, but they're not compatible with Munt. They probably need to be converted to something Munt can load.
User avatar
realnc
Postby dupaszaregoslonia » 2018-12-05 @ 16:54
You need to join them together. One byte from ic27, then one byte from ic 26, then one byte from ic27, then... :)
dupaszaregoslonia
Postby realnc » 2018-12-05 @ 20:37
dupaszaregoslonia wrote:You need to join them together. One byte from ic27, then one byte from ic 26, then one byte from ic27, then... :)
Yup. They need to be interleaved. I did that, and one of the control ROMs is weird. The 1.04, 1.05, 1.06, 1.07, and BlueRidge ROMs are already known to Munt. There's a new one (b__m-9.27c256.ic26.bin + a__m-9.27c256.ic27.bin) that is not. After interleaving it, it has these strings in it:
Code: Select all
Copyright (C) 1988 Real World Interfaces Australia 03-459-2889
Woe betide he who rips off my ideas!!! - Robin Whittle
What the heck is that about :confused:
Munt doesn't recognize it.
Update
The only things I was able to find out about "Real World Interfaces Australia" and "Robin Whittle" is something that seems to be a PCB design thingy for a memory board called "TX16W":
http://www.firstpr.com.au/temp/kicad-bu ... .kicad_pcb
http://www.firstpr.com.au/temp/kicad-bu ... II.PCB.brd
User avatar
realnc
Postby CODOR » 2018-12-06 @ 05:24
realnc wrote:What the heck is that about :confused:
There's a scanned copy of the documentation for the RWI mod here; I think it's a firmware and hardware hack to fix the sound quality and add a pre-reverb output and battery backup. My MT-32 had this done sometime before I owned it (and this reminds me that I should check the battery...)
User avatar
CODOR
Postby robbo007 » 2019-1-04 @ 09:39
I'm after the Roland CM.-64 ROMS. I have the original hardware but would love to try the ROMS on Boxer for MacOs. Have only ever seen the MT-32 and CM32 on my travels.
Thanks,
Rob
User avatar
robbo007
Postby Dominus » 2019-1-04 @ 10:44
1. Vogons is NOT a ROM trading site
2. CM64 or CM32 makes no difference in regards to games.
3. topic locked because of 1.
User avatar
Dominus
DOSBox Moderator
Return to MT-32 General
Who is online
