First post, by TotallyAccurateName
So, I know how to mount my drivers, but whenever I mount a folder that has a special/non-standard letter in it, it says that is doesn't exist. Ex; i can do "mount c c:\box", but can't do "mount c c:\låda".
This happens even if I use "KEYB sv".
This normally isn't a problem since having special letters in names of folder normal is a bad idea, but since I'm trying to get DosBox to work on a computer that has a network folder with the Swedish letter "ö" in the names of the folder. Note, I do not have permission to change the name fo the folder since its own by the network. I tried to look after a solution or someone with a similar problem, but I found posting here was going to be my best bet. Thank you.
Sidenote; I do believe I succeeded in mounting this driver one but only ones, but I may have been a fluke.
- Windows 10
- DosBox 0.74-2
