First post, by borgie83
- Oldbie
Hey guys. Firstly, my setup will be the following;
Roland MT-32 (Old)
Roland SC-55 MKII
Roland CM-64
Yamaha MU100
Roland MPU-401/AT or SCC-1A? Own both so your opinions would be appreciated. Assuming the MPU-401/AT given that the SCC-1A has an onboard SC-55 MKII and I'll be using an external midi module for that anyway.
Now I plan to run a midi through box to connect the midi modules and then run a through midi cable from the CM-64 to the MT-32. The reason for this is that the MT-32 will not be used for sound, purely just for messages via the LCD screen. The CM-64 will handle the MT-32 sounds. Next, audio cables will run from the midi modules to a Rolls MX44 Pro audio mixer which will then connect to my speakers.
Regarding my question, I know the Roland Super MPU64 can be used in Windows 98 but can it work as a standard midi through box via Dos? If not I also have an AmpTone Lab Midi Splitter I could use but I'd prefer to use the Super MPU64 so it doesn't sit there gaining dust so to speak.
