quicknick wrote:Cheers to all!
So I got this motherboard a few days ago, it came with a Celeron-533 and some cooler (not pictured). There are a number of caps missing (broken off the board, their legs still dangling there), and a few more that are severely bent and with at least one leg pulled off. So in order to restore this I think it's going to need a full recap. Problem is, from what I gathered from the 'net, this board only supports Celerons (is that even possible?), and I have no use for a Celeron-only board. I have no experience with Intel platforms newer than Socket 7, so I don't know what would happen if I toss on this board the only other So370 CPU that I have, a Piii-1266 Tualatin.
Of course it's possible that a board only supports Celerons. Intel's So370 platform went through three iterations, PPGA, FC-PGA and FC-PGA2. Each version was backwards compatible with the previous version (so you could run PPGA CPUs on FC-PGA boards and FC-PGA CPUs on FC-PGA2 boards) but not forwards compatible (so you can't run anything other than PPGA CPUs on a PPGA board).
PPGA was only used by the PPGA Celeron Mendocino CPUs, and this is an So370 PPGA board. Now, it's possible to hack the socket to allow FC-PGA CPUs to run anyway, but you then also need to worry about supported voltages (FC-PGA used significantly lower voltage than PPGA) and BIOS support. Tbh, not worth it. If you don't want to run Mendocino Celeron's, don't use this board.
That said, the Mendocino Celeron was a legendary CPU in its time, with the early version overclocking massively to 100MHz FSB and frequently outperforming the Katmai P3 at the same speed. For a mid 1999 build, this board with a Celeron 300A@450MHz or 333A@500MHz would be top of the bill.
