The worst sounding hard drive I've ever heard
Postby xjas » 2018-12-01 @ 21:45
Check out this beauty. 8-O
https://www.dropbox.com/s/gbzfvbly0jmmg ... 5.mp4?dl=0
HOLY crap. I was actually kind of stunned when it first spun up. It's LOUD; I can hear it with the case closed from the other room. Sounds like a bag of microwave popcorn going nuts.
Surprisingly it "works", it took a complete non-quick format with no errors and happily boots & copies files. I have no idea how this could be.
I paid four whole dollars for this thing too. >:(
User avatar
xjas
Re: The worst sounding hard drive I've ever heard
Postby keenmaster486 » 2018-12-01 @ 22:00
Sounds like it's about to fail :lol: *griiiiiind CLICK* *grind grind CLICK*
Well, the obvious solution here is to put noise absorbing foam all over the computer and then pretend the problem doesn't exist.
I flermmed the plootash just like you asked.
http://classictechnology.herokuapp.com
http://keenmaster486.github.io
IBM Thinkpad 600E, 560X, 365CD
User avatar
keenmaster486
Postby SW-SSG » 2018-12-01 @ 22:24
Yep... it's (almost) dead, Jim.
Those "clunk" sounds are the read/write heads being parked, as part of continuous retries of whatever read/write operations are going on in the video. Probably the heads are no longer aligned 100% properly anymore with the platter surface(s) (e.g. good luck fixing it).
User avatar
SW-SSG
Postby gca » 2018-12-01 @ 23:31
That is one sick drive. Even drives subjected to some extreme testing (I used to test disk arrays and some tests caused some very worrying noises) didn't sound that bad.
I hope you don't have anything important on there.
User avatar
gca
Postby spiroyster » 2018-12-01 @ 23:44
Worse than SCSI? I don't believe it...
User avatar
spiroyster
Postby realnc » 2018-12-02 @ 00:36
I had a drive that started doing that about 20 years ago. I demoted it to store my por... I mean unimportant, temporary crap, expecting it to die any moment now.
It lasted for another 3 years :lol:
User avatar
realnc
Postby Jo22 » 2018-12-02 @ 01:58
I agree with the other users, that hard disk drive doesn't sound too healthy. :(
I'm speaking under correction, but maybe the manufacturer's tools may help to "fix" the drive (low-level format, bad sector marking, etc.).
To me, it sounds like the drive is either loosing track/is misaligned or is set for an extreme form of power-saving
(since the heads repeatingly go to park position; however, there's no spin-down sound which contradicts this assumption).
User avatar
Jo22
Postby xjas » 2018-12-02 @ 02:08
Haha, don't worry guys, it's going in the bin. It wasn't "my" drive with anything on it, just one I picked up at a garage sale for a spare (hence the $4 price tag.) I was just so shocked by the noise I had to record it for posterity.
The head parking theory sounds reasonable, but it's awfully noisy even when it's not doing that... I still can't believe it formatted and boots. I even managed to get FreeDOS installed onto it. You can copy a file right through a "clunk" and it'll still work.
User avatar
xjas
Postby tegrady » 2018-12-04 @ 00:46
Yep, it's effectively dead. If there were any important data on it, I would copy it to a new drive ASAP. It's the "click of death".
User avatar
tegrady
Postby oeuvre » 2018-12-05 @ 13:41
typical maxtor
HP Z420 Workstation Intel Xeon E5-1620, 32GB, AMD FirePro V7900 2GB, SSD + HD, XP/7
Main Desktop Intel 6700, 32GB, AMD RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Postby Windows9566 » 2018-12-05 @ 22:54
i have that same maxtor drive in my macintosh performa 6200cd, it only shows 8gb but it works though
1995-Advanced/ML,P100,32MB-RAM,CL-GD5446,CT1740,WFWG-3.11/DOS-6.22
1996-VX97,P133,32MB-RAM,TRIO-64V+,CT1740,Win95-OSR2.1
2009-M2N68-AM-Plus,Athlon-64-X2-5600+,2GB-RAM,GTS-450,WinXP-Pro
2017-ROG-B450F,R5-1600,16GB-RAM,GTX-1060,Win10-Home
User avatar
Windows9566
Postby Baoran » 2018-12-06 @ 00:27
My Seagate ST31220A is the worst sounding hard drive I have ever heard. The sound is so loud and high pitch that I can't even handle being in same room as the drive even when it is not trying to read or anything. Otherwise it would be a perfect retro hard drive because it is 1Gb and it has an emulation mode where it emulates 500Mb master and 500Mb slave drive at same time for those pcs where you can't use bigger hard drives.
Baoran
Postby RandomStranger » 2018-12-06 @ 09:34
I had a 6.4GB Quantum Fireball until last Sunday. It sounded like a angle grinder.
I saved the data and tried to install a new XP on it. It took 5 hours, then short after finished, it went silent and gave of a bit of smoke.
User avatar
RandomStranger
Postby tegrady » 2018-12-06 @ 16:12
I have 3 WD1200 (120gb IDE) drives. They all work fine, but they sound like a jet taking off. They give off a very high pitch whine. It's almost unbearable.
User avatar
tegrady
Postby Baoran » 2018-12-06 @ 18:55
My seagate sounds about this at idle https://www.dropbox.com/s/f5xj9468sxvafw9/seagate.mp3
Sorry about the bad sound quality because my microphone isn't very good. It is loud enough that I can hear it when it is inside a computer and there is 2 closed doors between me and the computer.
Baoran
Postby xjas » 2018-12-06 @ 19:35
^^ wow, that's nasty. Sounds like the bearing grease has hardened into concrete. I have a 1GB laptop drive I can't use for that reason, it sounds like a dentist's drill ... going into your skull, after a while.
There's a little wrinkle to the story of the Maxtor drive in the OP - I sold it ... well, sort of. I was intending to use it in a system I was putting together to sell to a guy. After I heard what it sounded like, I told him I couldn't provide a HDD & knocked some cash off the price I'd quoted for the cost of a new one. He ended up taking it with that thing still in it, with full knowledge that it was going to die. He texted me later & said he'd gotten a complete Win98 install onto it and was using it despite the clunking while he looked for a new one & had no trouble "so far."
I asked him to text me back when it fails. Bwahaha.
User avatar
xjas
Postby SirNickity » 2018-12-06 @ 21:14
I have an old 420MB Quantum that sounded like a circular saw for a while after I first got it. I used it in a 386, and the bearings eventually settled down. Not quiet by any means, but not any worse than other drives of its vintage. Still works fine, but I was running out of space, so it got replaced with a slightly larger one.
SirNickity
Postby BeginnerGuy » 2018-12-06 @ 21:46
It could make a good addition to that floppotron youtube channel, with the musical floppies.
Sup. I like computers. Are you a computer?
User avatar
BeginnerGuy
Who is online
Users browsing this forum: DankEngihn, derSammler, dionb, FAMICOMASTER, georgel, imi, Moer, MSN [Bot], oeuvre, ricom2ger, Vynix, wiretap and 18 guests
