First post, by athlon-power
I know this is getting repetitive, but at the same time, I feel like I'm close to getting HL running smoother than it is right now.
I made a thread before about having performance issues with HL on this system:
Intel SE440BX-2 Motherboard
Intel Pentium III Katmai 500MHz/512KB Cache/100MHz FSB
256MB PC133 RAM @100MHz
ASUS AGP-V3800M SDRAM, 32MB (nVidia Vanta TNT2 M64)
AOpen AW744L II Sound Card
48X Samsung IDE CD-ROM
WD400 Caviar 40GB IDE HDD
3.5" 1.44MB FDD
At the time, I had a Coppermine @600MHz in it, and I was seeing frame drops, low FPS, etc. Through that thread, it was determined that Half-Life is a very CPU-intensive game, and that even PIII Coppermines @800MHz ended up having issues with the game. However, when I think back on it, I used an nVidia GeForce FX5200 AGP card in it early on, because I had no time-accurate card that could really play anything all that well. Here's the catch: it ran fine, with the 500MHz Katmai (before I changed out the decaying thermal pad with thermal paste, and using a passive heatsink!). I'm starting to think that it's because the FX5200 was drawing a decent amount of rendering load from the CPU.
My question is now, is there a GPU released before/during mid-1999 that did something similar? I do own a GeForce 2 MX400 AGP card, and I'd test it with that, but the whole reason as to why I was using the FX5200 early on in the first place is because the GeForce 2 didn't work very well with the i440BX Chipset on the Gateway Tabor III motherboard I was using at the time, and the motherboard I'm using either has a very similar chipset, or the same chipset. The GeForce 2 refused to render Half-Life, and would crash very, very often. I tried the Savage 2000 on that board, and it did the same thing, so I might have luck on this new board if I use older drivers. I think I'm going to change out the V3800M with the GeForce 2 and see what happens.
I will post an update as to what happens. If it works fine, and runs better, I'll know that the card should be drawing some of the load from the CPU.
I do want to know if any time-accurate (mid-1999 and before) GPUs were known to be able to take some load off of the CPU, and give the system a leg up in rendering capability. If the GeForce 2 works, in the meantime, I will use it, until I can get a more time-accurate card. I'll have to wait a while before I get enough money to buy anything like that, however, I am thinking that VooDoo 2's might be a viable solution. I theoretically wouldn't have to replace the ASUS card, and could just plug the VooDoo 2's into the system, I do have 3 free PCI slots. (the system has 4 PCI slots, two ISA slots- one is a combo ISA/PCI slot, only one of the two can be used at a time in it, and an AGP slot).
Where am I?
Reply 1 of 17, by athlon-power
That's a "nevermind" if I've ever seen one. Half the time, the system won't boot properly with the card installed, and Windows refuses to work with it. The times that the system just sort of crashes are usually right before Windows gets to the desktop. There's also artifacting on the System BIOS screen in the form of small white dots, while there is none present on the actual video card BIOS screen. I will try cleaning the AGP contacts on the card with some rubbing alcohol, but if it continues to crash or otherwise malfunction, I will have to diagnose this one as chipset incompatibility.
It's odd though, because I could boot up the PC and install drivers and use Windows normally just fine on the Tabor III. That's why I think this has something to do with the AGP contacts having dirt on them or something like that.
[EDIT]
This isn't going to work. After removing the card, and cleaning the contacts, and checking it for any signs of issues, it still has the same issue. It will artifact small white dots above and below characters in BIOS, and some in DOS mode, and Windows 98 will refuse to load the video drivers, with this error:
"There is a problem with your display settings. The adapter type is incorrect, or the current settings do not work with your hardware."
This has nothing to do with the drivers themselves, or even Windows, as it's artifacting in BIOS. I'm going to say motherboard incompatibility, as the video BIOS itself is free of any artifacting. The system will hard-lock up when I click "ok" on the message, and it will respond to nothing but the reset button. The BIOS is fully updated on the motherboard.
Where am I?
Reply 2 of 17, by leileilol
Half-Life's from before the time of hardware T&L and what you're suggesting hasn't been a thing until after 2000. Offloading vertex processing to the GPU was a constant struggle (Voodoo2's much lauded "triangle setup", DX7's HWT&L, OpenGL2's vertex shaders and VBOs, and Vulkan) and that was only applicable to games that used the modern and newer APIs and took advantage of them for appropriate hardware.
tl;dr there is no miracle Half-Life low-end stutter solving video card.
Reply 3 of 17, by athlon-power
I'm thinking that the stutter itself is from the game loading while doing things. I'm honestly not even looking into low-end anymore, either. I just had the GeForce 2 MX400 lying around, and that's why I tried it.
I read somewhere that the GeForce 256 actually does something like that. Checking it right now, it does mention that the GeForce 256 is T&L capable, but the game has to support it. Unless there's an update to Half-Life WON that was made that specifically allows for T&L. I'd have to do some research into that. Of course, that's assuming that I ever get the ungodly amount of money required to get a GeForce 256, which unless something unexpected happens, I'd doubt.
So I'm probably going to be stuck here for a while. To be fair, it does run alright, but it's very inconsistent, running for, I'd say 55% of the time at 37FPS, and going to 50+ FPS. But in that other video thread, it was discussed that the game just runs poorly, at least, the original WON version does. I'm not sure why it ran so well on that FX5200 if it wasn't for T&L, however.
[EDIT]
Looking around a little bit, I found this site which seems to have a HL update version up to 1.1.1.2. I'm not 100% sure of the legitimacy of this, but this seems to be made by the makers of WON2. I'm wondering if T&L support was thrown in there somewhere.
https://v5.steamlessproject.nl/index.php?page=hl1112
Where am I?
Reply 4 of 17, by BeginnerGuy
I think Geforce 256 was the first GPU with hardware t&l, but like leileilol said, the game engine itself had to specifically use a version of OpenGL / DX that supported such a feature. That said, it may be possible that modern versions of HL through steam may have been updated, but I doubt it.
My 800mhz coppermine doesn't have 'problems' running Half-Life per say, it just has dips into the 30s when certain AI are rendering. This was absolutely normal back then, nobody had a PC good enough to get a solid 60FPS in brand new AAA first person titles. I knew a few crazies who ran dual pentium 3 coppermine setups just to play Quake 3 and Unreal Tournament, but besides them, must humans accepted 30FPS as a very good baseline.
I'm afraid the only way you're going to lock in Half-Life to 60+ FPS rock solid is going to be by using a Pentium 4 or Athlon XP though I expect the experience would be very smooth using a 133mhz bus top end Coppermine or Tualatin. Unfortunately my slot 1 board with 133mhz bus doesn't work anymore to test this out. I would try to get somebody running a 1ghz coppermine @ 133 to bench the game and then maybe a 1.4ghz Tualatin to see how far ahead of my system they get.
FWIW I've tested half-life all the way up to a GeForce FX5600 and the frame rate remains the same, even at 640x480, it's totally CPU bound.
Sup. I like computers. Are you a computer?
Reply 5 of 17, by athlon-power
I don't exactly want a solid 60FPS, I just wish I'd get it to at least 45FPS or so, and stay somewhat consistent with that.
Though, the mention of a dual processor configuration does strike me as plausible, if I managed to get the funds for a dual slot 1 motherboard. Other Katmai's @500MHz are fairly cheap, or I could replace the 500MHz entirely and just get two of the fastest PIII's released in my system's timeframe, the Pentium III Katmai 600MHz model.
That is probably extremely expensive, however. I've looked up dual Slot 1's on eBay before, and they never dip below US$100. Usually, they range in above US$130.
Where am I?
Reply 6 of 17, by BeginnerGuy
I should add that I don't believe Half-Life can use SMT (Multithreading / multi cores). Such being the case, you would see no improvement at all.
It's too bad we can't overclock the SE440BX-2 for a bit more testing, though you may be able to get away with buying a coppermine capable slotket and a 1000mhz socket 370 coppermine at a reasonable price. 1000mhz slot 1 Coppermines are very expensive and it seems anything above 800mhz doesn't show up often on ebay. Or if you were looking into a whole new board, Pentium III Tualatin boards can run 1.4ghz CPUs, that's almost twice the clock speed of mine, so I would imagine the frame rate would be much better overall.
I have a feeling this chip would blow mine away at 1400mhz + 133mhz bus.
https://www.ebay.com/itm/COMPAQ-G2-PENTIUM-3- … &frcectupt=true [I don't know or endorse the seller, just an example]
Reply 7 of 17, by athlon-power
If you run Half-Life at 400x300, it's quite smooth. I am still using OpenGL, but it looks like you'd expect it to. I'll try a couple of other display modes (DirectX, Software.. ew.) and see how my mileage varies.
I was joking about 400x300 50% of the way, and the other half, I may fall back on 512x384 in OpenGL or something similar. I did try 1024x768 earlier on, and the FPS was awful, but it never approached single-digits, always staying above 15fps, so I guess that's got to count for something.
My motherboard supports a maximum of a Pentium III 800, so that's as far as I could take it. I don't know how well a faster CPU on a slocket adapter would work, or even if it would work at all.
Where am I?
Reply 8 of 17, by leileilol
it isn't and they haven't. It's also not trivial to add (Especially for a 'patch' which just switches some IPs around)
Reply 9 of 17, by misterjones
If not the Geforce 256/Quadro, I do remember the Savage 2000's only claim to fame was that for a brief period it was known to be the fastest card for Quake 3 Arena in 32 bit color; might be worth a look. Aside from that maybe a TNT2 Ultra, Power VR Kyro, or something along those lines.
Reply 10 of 17, by Garrett W
Did you try turning V-Sync Off like I suggested in that thread? I'm fairly certain it will fix performance for the most part. Half-Life probably uses double buffered V-Sync, unless the TNT2M64 drivers allow you to use Triple Buffered VSync.
Reply 11 of 17, by mzry
The M64 is an absolutely horrible card and will be the source of your problems for sure. For the 1999 period get yourself a Voodoo 3 3000/3500 or a matrox g400/g400 max. They would suit your machine very well.
Also since you mentioned loading stutters, check that your HDD is running in DMA mode and not PIO mode. This used to be a common issue for me back in the day.
Reply 12 of 17, by Katmai500
Even a regular TNT2 would be a big improvement. The 64-bit memory bus on the M64 is a major limitation.
Reply 13 of 17, by Tetrium
I'll have to disagree with your statement about the TNT2 M64 being an absolute horrible card.
It simply is not.
It's biggest gripe may be its limited speed, but only compared to faster/newer cards.
TNT2 M64 is quite a good card actually, it's one of those cards that simply "just works", but isn't the fastest solution you can easily find (any MX2/MX4 card is most likely going to be much faster and as easy to find I suppose).
The speed of the TNT2 M64 is roughly comparable to TNT1 (for instance Diamond Viper 550) and there are PCI versions of this card.
My retro rigs (old topic)
Report spammers here!
Reply 14 of 17, by silikone
Half-Life's OpenGL interfacing is anachronistic, to say the least.
There are a couple of things John Carmack and Brian Hook addressed since the release of GLQuake that the Valve engineers did not. For example, Half-Life is still using the immediate mode with an API call for every vertex or strip. Quake 2 has some variables for enabling the usage of the superior OpenGL 1.1 calls. Another thing that is especially relevant for Half-Life's flashlight is the lack of a dedicated dynamic lightmap atlas. It is not unusual for the flashlight to manifest itself on three different 128x128 lightmaps that are to be updated every frame, which is a performance killer on PCI cards.
Generally, 3dfx chips had the least driver overhead at the time, so I guess a Voodoo 2 is the most appropriate card for a CPU intensive game like this (or the Banshee for that nice multipass overbrightening).
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 15 of 17, by Scali
For DirectX that certainly is true. Namely, in order for hardware T&L to work, you need to have the vertex data in VRAM beforehand (otherwise the T&L units would get bottlenecked by the PCI/AGP bus, and there would be little or no gain).
Since DirectX is quite low-level, the vertex data was very explicitly in system memory in early versions of DirectX. DirectX 7 was the first to introduce the concept of vertex buffers, and allowed the user to specify whether they be stored in system ram or VRAM.
OpenGL is different however. There are various ways to send vertex data to the OpenGL API, and they don't really specify where and how the OpenGL layer should store that data. To the user, the API is just 'fire and forget'. This high-level abstraction makes it relatively easy for the driver to buffer vertex data, and render the data in batches (which was already a relevant optimization even before hardware T&L). This also means that adding support for hardware T&L is quite trivial (although the PowerVR cards proved that a buffered approach can also be implemented for DirectX, but afaik no other manufacturer ever tried such an approach).
Of course, this is all driven by heuristics, so in practice it still depends on how draw calls can be grouped together. Changing certain attributes would force the driver to flush the buffers and start a new batch. Worst-case, this happens at every individual triangle.
That is the biggest downside of the usage of a classic BSP, as in the original Quake engine (also used by Half-Life): the triangles arrive in more or less 'random' order, one by one. Very efficient for software renderers, not so good for batching calls.
This led to the development of 'leafy' BSP trees, where the BSP would not return one triangle at a time, but rather groups of triangles, to improve GPU efficiency. Half-Life is too old for that though.
TL;DR: OpenGL games not specifically designed for it *can* benefit from hardware T&L, but not necessarily. GLQuake and Half-Life are quite poor cases for hardware T&L.
Reply 16 of 17, by leileilol
I'd like to use GF2-gen T&L in OA some day and even I haven't figured where to start, especially since Id Tech 3 by nature is a unified brute-force software processed approach to go through the same strip functions it'd need a complete rewrite to even have it all reproduced in vertex shaders. Losing the CPU overhead from that would be super nice though, and I know Harekiet (yes) did an ARB'd q3 renderer at one point.
Reply 17 of 17, by Scali
Heh, when I first read that, I thought it applied to DOOM 3, but that's Id Tech 4. Same thing though: they did a LOT of stuff on the CPU there, didn't leverage shaders for the stencil shadows.
I never quite understood that decision: now you needed a 3+ GHz Pentium 4 or a 3000+ equivalent Athlon to process the shadows quickly enough, where most shader cards available at the time would have been able to do that easily, with a much slower CPU.
A great example of that is the Battle of Proxycon test in 3DMark03: https://www.youtube.com/watch?v=Uw2XLhjihKc
They do make full use of shaders, and it scales much better with newer hardware than DOOM 3 did.
I also took that approach for my own engine's stencil shadows back in the day (obviously with a CPU-based fallback for older hardware, but still making use of T&L where possible: I stored the stencil shadows in object space in VRAM and updated only the required data on-the-fly with the CPU, then let the GPU handle T&L).
