Reply 2160 of 5019, by bjwil1991
sf78 wrote:
Someone dropped this at work. Looks pretty neat, but the awful Toshiba 4200 rpm HDD with that stupid LIF connector makes upgrading it a pain in the ass and not really worth the effort. Also I think the RAM limit is 2 Gb, but should be enough for XP.
https://www.cnet.com/products/dell-latitude-d420/specs/
Is it a 40-pin ribbon cable that connects to the hard drive? That's Dell for you. Looks like eBay has a bunch of the ZIF/LIF SSDs on there.
Reply 2161 of 5019, by liqmat
Don't know about this model, but many motherboards and laptops will say "2GB limit". I have been able to upgrade many boards and systems to 4GB with no problems that say 2GB max. Usually recognizes 3GB to 3.5GB total once the 4GB is installed. You just have to try per system and see what happens.
Reply 2162 of 5019, by bjwil1991
The system has 512MB soldered onto the motherboard and only has 1 slot for the RAM according to the documentation.
Reply 2163 of 5019, by SW-SSG
sf78 wrote:
... Looks pretty neat, but the awful Toshiba 4200 rpm HDD ...
Not shocking; there is anti-virus software and torrents and who knows what else on there. :p
Reformat and reinstall with a smaller load of software, pay attention to startup processes, defrag once in a while and it should be OK... still somewhat laggy compared with a regular 2.5" HDD but undoubtedly better than it is currently.
Reply 2164 of 5019, by xjas
I have one of those, it's not the fastest thing in the world but it has a great keyboard and a pencil-eraser trackpoint thing which is pretty neat on a non-Thinkpad. Never noticed the HDD slowing things down, to be honest. You can get PCI slot docks for them dirt cheap. I'd probably still be using mine regularly if the LCD inverter hadn't died; great little laptop.
AFAIK the D420 can "unofficially" go up to 2.5GB - put a 2G stick in the single slot. The D430, which I have, has 1GB onboard but is limited to 2GB.
Reply 2165 of 5019, by liqmat
ah, i see.
Reply 2166 of 5019, by sf78
My mistake, this is actually D430. There was a typo when I searched for the specs.
Regarding the HDD upgrade...If it doesn't boot in 30 seconds it's too slow. 🤣 The interface used is the limiting factor, you can't get best speed even if you swap a modern flash drive and adapter inside. It might shave off 20 seconds of the boot, but I'm not really looking to spend 20-30e on a system that is borderline useless in anything but retro things. Well, I might be able to run 720p clips on YT. 😀
Reply 2167 of 5019, by Baoran
Sometimes you still find treasures. I haven't found much this year. I found just 30 minutes ago a sound blaster in local recycling center that has a SCSI. Never seen a sound blaster with that before.
The attachment ct1770.jpg is no longer available
I hope it works. Can you use scsi hard drives connected to it or is it just for optical drives?
Reply 2168 of 5019, by bjwil1991
Optical drives, I'm afraid since there's no way to boot off of a hard drive connected to it, however, somebody with more experience with SCSI drives can provide a better answer than me.
Reply 2169 of 5019, by luckybob
Oh, you can put anything on that card. Even hard drives. You just can't boot from it.
Reply 2171 of 5019, by Baoran
That sound blaster card I found seems to be working otherwise, but my SC-55 doesn't seem to like being connected to it for some reason. Power won't turn on in my sc-55 if it is connected to that card. If I disconnect the midi cable SC-55 turns on. If I connect midi cable while it is turned on, it plays midi fine. But because of that issue I did put back my old sound card back there.
During the same trip to the recycling center I also grabbed this radeon agp card, but back home I noticed faint smell that might indicate that it isn't very likely to work. Not sure if it is worth testing.
The attachment radeon1.jpg is no longer available
Reply 2172 of 5019, by AlaricD
I watched an idiot totally smoke the SCSI cable hooking it up backwards on CT1770. Wild seeing 45-50 bare wires in the air with the insulation burned off.
Strangely, the card still worked after that-- I thought it was a goner.
Reply 2173 of 5019, by Baoran
Perhaps it is a good thing that I don't own a SCSI drive yet 😜
Actually never touched SCSI stuff yet, except one controller card I have somewhere...
Reply 2174 of 5019, by luckybob
That story REALLY seems farfetched. I dare say impossible.
Reply 2175 of 5019, by Tetrium
What were you doing looking at that idiot anyway, without even trying to interrupt him? 😜
My retro rigs (old topic)
Report spammers here!
Reply 2176 of 5019, by Baoran
I tested the radeon video card and it seems to be radeon 9800XT and it works, but I don't think it is usable because the fan is about to fail. The fan makes lots of nasty noises when rpm goes even bit higher and it even stalled for a second few times, so I didn't run it more than 10 minutes.
Reply 2177 of 5019, by gdjacobs
See if you can pump the bearings full of oil based lubricant (I used petroleum jelly). I did that with a seized Radeon 9100 fan and it's been resurrected for years.
Reply 2178 of 5019, by Baoran
Would gun oil have too low viscosity to be used in something like that?
Reply 2179 of 5019, by cyclone3d
Gun oil might be kinda thin. I always use 5w-30 or 10w-30 full synthetic motor oil. Haven't had to re-oil a single fan in years. Best to take the fan apart and clean all the dried up oil and dirt out first though.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
