First post, by ROCKandROLL
ROCKandROLL
Offline
I just cannot get this to work. I mount disk 1 on drive A and the install begins. It complains of some weird redirection error and then begins installing fine. When it want the other disks I switch to windows and put them in the directory. Everything goes fine until the end where it says its missing a few files. Then I try to run the game in dos and it says illegal command: sierra.
Is there a way I can extract all the install files from the floppys instead of running the install?
